Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS430
Sign in using an external account
Register Forgot Password?
Changing the DRLs
Thread Tools Search this Thread Display Modes
Old 09-14-14, 08:00 AM   #1
roumieh200
Trader Score: (0)
Default Changing the DRLs
I want steps to get my DRLs replaced as I couldnt find thread to show step by step DIY, and I found it too hard to remove the headlight out to get that DRL bulb out and it shows that its tightened with two screws which makes it almost impossible to get it changed without getting that headlight out.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
roumieh200 is offline   Reply With Quote
Old 09-14-14, 10:09 AM   #2
Lavrishevo
Trader Score: (1)
Lavrishevo's Avatar
The daytime running lights are actually just the high beams running at 6v. You should be able to refer to your owners manual about replacing these lamps. It is also recommended that you replace both at the same time. Never touch the lamp itself. The oil from your skin will cause premature failure. I always clean halogen or hid lamps with 90% rubbing alcohol before installation whether I accidentally touched the glass or not.
__________________
2004 LS430 UL
1999 LS400
Lavrishevo is offline   Reply With Quote
Old 09-14-14, 11:43 AM   #3
SaleenS7
Trader Score: (0)
SaleenS7's Avatar
Batman
Hey friend,
This will give you step by step instructions to replace the DRL bulbs.
http://www.carcarekiosk.com/video/20...light_runnings
Off topic here but I was trying to install LED DRLs (knowing it would mean losing highbeams) but after buying the LED 9005 bulbs on amazon I realized it wasn't exactly plug and play like I had read on here when I searched. =/ If anyone has a DIY on installing the LED DRL I would be very grateful!
__________________
2004 LS430 Sport package, Modern luxury package, smart access.
2006 Subaru Impreza WRX STI
SaleenS7 is offline   Reply With Quote
Old 09-16-14, 09:43 AM   #4
BigLS430
Trader Score: (2)
They can be turned off via the ecu with the techstream programmer from ebay or the dealer. I just turned mine off cuz the **** yellow coloring annoyed me.
BigLS430 is offline   Reply With Quote
Old 09-16-14, 09:46 AM   #5
roumieh200
Trader Score: (0)
Quote:
Originally Posted by SaleenS7 View Post
Hey friend,
Thanks for the reply, however this video only shows little since its meant only for changing the little bulbs above the DRLs, I still need instructions to take them out with the headlights
Hope someone will have something to participate with.
I found a picture but not sure about since it shows that we need to remove the bumper to be able to remove the headlights assembly.
http://ww2.justanswer.com/uploads/br...8_173740_3.gif
Old 09-16-14, 09:52 AM   #6
roumieh200
Trader Score: (0)
I am sure this will help: http://www.clublexus.com/forums/ls43...-and-leds.html
He is saying in the post: Start by removing headlight from car.
3 10mm bolts to get one side of bumper off and 3 10mm to get Headlight out.
Old 09-16-14, 10:31 AM   #7
rkw77080
Trader Score: (0)
Hey friend,
For the LS430 the DRL is the highbeam burning at reduce voltage. You should select the video for replacing the highbeam bulb. The site did not use a LS430 on the video, but the procedure is the same.
rkw77080 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Projector headlight DRLs yardie876 NX Models 4 09-14-14 08:55 AM
drls question ca 714 oc koolwip350 IS - Second Generation 2 08-10-14 11:15 AM
Dealer says they can't turn off DRLs Reaper21 IS F 30 06-05-13 07:38 AM
Installed the ijdmtoy LED DRLs ...what a PITA RCM83 IS F 60 05-17-13 08:23 PM
Changing bulbs on DRLs HAiS250 IS - Second Generation 14 02-22-12 04:45 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
