Look.... what I found under my battery tray
Old 09-10-14, 12:55 PM
xtr3me
xtr3me's Avatar
Default Look.... what I found under my battery tray
Another battery depleted .... Super Start Extreme - bought from O'Reilly's which lasted 37 1/2 months (3 yr warranty)... Super Start Extreme battery in my truck lasted for 40 months, also just outside free replacement warranty... so I'm not bragging on them nor am I trashing them, good for 3 years.
Now on subject, after removing battery I decided to pull my battery tray because I was concerned with the rust on the bolt head and washer of the bottom mounting bolt. I replaced bolt with a stainless steel bolt and washer from my bolt bin. The bottom of the tray had what appears to be acid residue/corrosion and the bushing shows evidence of rust as can be seen in photo... I cleaned up the tray, removed rust from bushing with a wire brush attachment using a drill. Painted with a primer and then painted with automotive paint to prevent further rusting. Note the hole just above the rusted bushing on battery tray, closest to the snub nose screwdriver. That is the drain hole... Remember that
Remember that drain hole I spoke of earlier... Well, here is the drain tube that sits below that hole in the tray. I pulled it up for viewing only, no need to remove. Either blow air thru it or rod with wire or similar to ensue it is free of any debris.. Tube was stopped up, not allowing any drainage, therefore any form of liquid (water/acid) leaked along side of the bottom tray bolt, eventually causing rust damage due to future owners, dealerships and my own maintenance neglect.
* Preventive Maintenance Checks & Services - check drain tube to ensure it is free of any blockage everytime battery is removed or replaced *
Cleaned up rust surface with a cordless drill and wire brush attachment. Sprayed and wiped with ' Wipeout ' grease and wax remover. Applied 2 coats of a corrosion resistant primer in aerosol can by ' Nason ' (421-24) and followed up with 2 coats of an aerosol automotive paint . Best if I used something like Por-15 but I used what I had around the house. So ...lesson learned here - when battery is removed for whatever reason, a 10 seconds can prevent a lot of headache
Old 09-10-14, 02:58 PM
Lavrishevo
Lavrishevo's Avatar
I was expecting maybe an old coin or something cool... Not a rusty bolt.
Old 09-10-14, 04:39 PM
rrgone
rrgone's Avatar
Yeah, or the key to former owner's safety deposit box!
Old 09-11-14, 04:51 AM
AlexusAnja
AlexusAnja's Avatar
I thought maybe the keys to an LF-A... rust you can find at any GM lot...
Old 09-11-14, 10:50 AM
Lavrishevo
Lavrishevo's Avatar
Hey xtr3me, I just wanted to tell you I was teasing you. Your post are informative. Keep it up.
Old 09-11-14, 02:05 PM
xtr3me
xtr3me's Avatar
I want a LF-A... I confess, I'm guilty of watching all the FL-A Youtube videos
No worries, I love the responses...
I like the way you guys think...
Now if I could just get my name added to each of your B-day and Christmas lists !
Did I mention, I want a LF-A
Old 09-11-14, 04:48 PM
Lavrishevo
Lavrishevo's Avatar
Refurbish my headlights and this baby is yours:
http://www.ebay.com/itm/like/400692510141?lpid=82
Old 09-11-14, 11:20 PM
xtr3me
xtr3me's Avatar
That's funny...
Send me them headlights whenever you can, I got you...
Old 09-12-14, 06:06 AM
DavidinCT
DavidinCT's Avatar
....rust you can find at any GM lot...
This thread just proves you could see rust at any lot, even Lexus
Paul B
10-20-13 12:15 PM
smokyis350
03-25-12 05:21 PM
philly777
GX - 1st Gen (2004-2009)
12-03-08 08:31 AM
nysupraman
Performance & Maintenance
02-12-05 10:28 AM
Quick Reply: Look.... what I found under my battery tray
