Anyway way of setting height for BC coilovers
Old 08-18-14, 07:15 AM
mikedc26
mikedc26's Avatar
Default Anyway way of setting height for BC coilovers
I just installed some BC coilovers already put about 600 miles on them. They already set but are on even.
Question- How to set it to were its even?
Right now my Left Rear and Right front are the same ride height and my Right Rear and Left front are the same ride height.
I drove up a driveway yesterday and my Right Front wheel got the fender. Need to repair and paint fender cause of that. I will upload a pic later
Old 08-18-14, 07:43 AM
DriftGirl
DriftGirl's Avatar
Old 08-18-14, 09:59 AM
SQuester
SQuester's Avatar
Low ride height + flush wheel fitment=new driving technique. You have to angle into driveways and over speedbumps while keeping the wheels straight until you're over the crest or obstacle.
Old 08-18-14, 10:12 AM
1sWt2GS
1sWt2GS's Avatar
Originally Posted by DriftGirl
I LOL'd.
Gotta pick up a new way of driving. I'm slammed and honestly path my routes differently to avoid bad streets, speed bumps, etc.
Old 08-18-14, 05:23 PM
LiCelsior
Retired
LiCelsior's Avatar
Old 08-22-14, 04:25 PM
RushNatU
RushNatU's Avatar
I use these to measure, much more accurate.
Old 08-23-14, 07:43 PM
mikedc26
mikedc26's Avatar
Will do. Both fenders getting painted this weekend then after reassembly going to lift up the rears and front just a bit
Old 08-24-14, 05:34 AM
RushNatU
RushNatU's Avatar
I dont have BC coilovers on the LS but i do on a Maxima and have done a lot of adjustments. Be careful not to use a mallet on the wrench to tighten the lock rings down. It will damage the spanner wrench and the lock rings, don't ask me how I know, lol. Also, to set the height, you loosen the lock ring on the bottom shock mount and thread the whole shock body into the bottom shock mount. If you mess with the spring preload, just measure from the bottom spring perch to the top of the thread first so you know where it's original position is. Also, when you fist set the height, it will be slightly higher until you drive for a bit, and then it'll settle. Cheers.
sangha333
04-07-19 07:13 PM
project350
Suspension and Brakes
05-15-17 09:37 PM
BradM209
IS - 1st Gen (2001-2005)
03-13-16 07:02 PM
Yamaheart
13
01-06-11 10:43 AM
bonafyd
06-08-09 03:17 AM
Quick Reply: Anyway way of setting height for BC coilovers
