Rear Driver Side Parking Sensor Keeps Going Off
Old 07-25-14, 07:41 AM
jdotlim
jdotlim's Avatar
Default Rear Driver Side Parking Sensor Keeps Going Off
Hello,
I know every time you press the master switch for the parking sensors that the system goes on a full system check. All the sensors work, and I do not get any messages to clean or having a faulty sensor. But when I put the car into reverse. The driver side rear sensor keeps going off, even when there is nothing near by the sensor. I tried resetting the sensors, but switching the master switch off and on, it worked for a little, and it came back. Any feedback would be great. Thanks.
The car is 2004 model, if that is needed.
Old 07-25-14, 04:13 PM
LS430inDE.
LS430inDE.'s Avatar
Is it possible there's a tiny bit of contamination on the surface of the sensor? Bird dukie, bug remains, or perhaps the paint is flaked? I had a similar issue except it was on the driver side front bumper. A rock or armored bug (lol) must have hit it and chipped the paint on the circle! I gently sanded with very very fine sand paper, the sensor. I then painted over the black circle with Toyota/Lexus touch up paint. I NEVER had an issue after that. (I read the solution on here!)
If that doesn't work, I think it's reasonable to assume the sensor is just "going bad". Electronic devices can last 50 years, or 5 days. You just never know.
Old 07-28-14, 07:41 AM
jdotlim
jdotlim's Avatar
I just sanded down the sensor, so far so good. No beep or anything when I am far away. Hopefully it stays like this for ever. Thanks for your help.
Old 07-28-14, 02:35 PM
LS430inDE.
LS430inDE.'s Avatar
Thumbs up nicely done!
That is awesome! Thanks for taking the time to post a reply that the solution worked!
TriniLex
07-09-17 07:25 AM
jbone29
05-31-17 11:07 AM
cashnymd
03-19-12 07:25 AM
CelsiorAUS
08-07-10 07:14 AM
gs4bkny
08-25-09 08:38 AM
Quick Reply: Rear Driver Side Parking Sensor Keeps Going Off
