Front lower control arms
Old 07-16-14, 06:18 PM
Zodiac
Zodiac's Avatar
Default Front lower control arms
My 04 LS has 120k miles and the front left lower control arm smaller bushing is cracked and making noises. I replaced the bigger lca bushings already. It doesn't look like the smaller bushing is replaceable by itself. How long do these front lca last on the ls? Has anyone replaced their front lca before and do you recommend replacing them in pair meaning front left and right?
Old 07-17-14, 01:19 AM
jackjumper
jackjumper's Avatar
Anything suspension related should always be replaced in pairs. As far as replacing them I have no experience on my LS but I am willing to bet it is the same as any other double wishbone setup. One very large bolt that goes through the bushing. Remove the old and press in the new. A little bit of grease will help when pushing it through the rubber pieces. Just be sure you use a grease that's safe on the rubber.
Old 07-17-14, 01:28 AM
jackjumper
jackjumper's Avatar
Here is the procedure from my service manual. If you decide to do it yourself always make sure to get an alignment done.
File Type: pdf
Old 07-17-14, 07:08 AM
Zodiac
Zodiac's Avatar
Jack thanks for the manual but not going to DIY since I don't have a press for the big bushings.
Old 07-17-14, 08:06 AM
ancdmd
ancdmd's Avatar
If you're just replacing the arm and not the rearward big caster bushings then you don't need a press, just unbolt everything and swap out the arm.
Old 07-17-14, 03:44 PM
Bocatrip
Bocatrip's Avatar
My front lower control arm bushings have been cracked for the last four years. . I get an occasional front end clunk during hard steering while leaving a parking space. My tires are wearing fine and there is no play in the steering. My independent shop told me there is no rush to replace.
Old 07-17-14, 04:21 PM
jackjumper
jackjumper's Avatar
The bushing assembly is $88 with CL discount at Sewell but that would still leave the bushing in the LCA. They can be pressed in with a vice. They're usually two pieces.
Old 07-19-14, 01:01 AM
Doc Yota
Doc Yota's Avatar
My 02 just recently started making the same sounds described here. My cousins 02 has had this problem for years and could never pinpoint the problem. I think I know where to start now....
Amnesiac
06-08-17 12:41 PM
JAB
RX - 1st Gen (1999-2003)
11-07-08 10:53 AM
Quiller
09-21-05 11:29 AM
brit_lex
07-09-04 07:35 PM
persian451
10-22-03 10:33 PM
Quick Reply: Front lower control arms
