Sanding and polishing the headlights
Old 07-14-14, 10:23 AM
Lavrishevo
Lavrishevo's Avatar
Default Sanding and polishing the headlights
Finally broke down and did mine. It was a lot of work. I'm not 100% satisfied with it yet but I was able to remove almost all the pitting and clean up the lens.
800 wet sand
1500 wet sand
3000 dry sand
and then polished out.
Attached Thumbnails Sanding and polishing the headlights-image1235017593.jpg   Sanding and polishing the headlights-image1711199644.jpg   Sanding and polishing the headlights-image37173449.jpg   Sanding and polishing the headlights-image744207262.jpg   Sanding and polishing the headlights-image566453206.jpg
Old 07-14-14, 10:24 AM
Lavrishevo
Lavrishevo's Avatar
Finished product. The little bit of blur on the drivers side is wax not wiped off. Don't know if I want to clear coat or do another type of protection on the lens. I'm happy with it. Just don't want it to degrade.
Attached Thumbnails Sanding and polishing the headlights-after-l.jpg   Sanding and polishing the headlights-image-1773418066.jpg
Old 07-14-14, 10:56 AM
SBlexus
SBlexus's Avatar
Looks great, just keep a good wax sealant protectant on them. Certain types of clear coats will just scale up.
Old 07-14-14, 11:32 AM
e60bmw
e60bmw's Avatar
It looks good, but you must seal the lights after polishing them. Opticoat would be a good option but its a little pricey, you may be able to mix your own sealer or get a sealer locally. I use one called blue something, got if off amazon.
Old 07-14-14, 11:56 AM
Lavrishevo
Lavrishevo's Avatar
I just ordered a bottle of the Blue sealant off of Amazon. Probably will polish one more time before I seal it.
Old 07-14-14, 02:25 PM
Bocatrip
Bocatrip's Avatar
If you periodically wax it as you see any hazing you can keep it looking as it is now. I had my mom's Honda sealed and it eventually peeled off and I had to do them again.
Old 07-14-14, 02:57 PM
1WILLY1
1WILLY1's Avatar
looks good , im afraid to do mine because I dont have a proper sealant yet.
On my sc400 I did this and they got yellow within a few weeks because I didn't wax or seal them.
Old 07-14-14, 06:07 PM
BradTank
BradTank's Avatar
I used the Sylvania kit on mine, I was really happy with the results. The clear coat stage at the end was what really made them pop. It's been about a year now, and no yellowing that I can see.
Here are the before and after:
Attached Thumbnails Sanding and polishing the headlights-securedownload-1.jpg   Sanding and polishing the headlights-photo-12.jpg
biacs
05-26-18 04:37 PM
ThomasGS4
Automotive Care & Detailing
32
12-26-14 12:21 PM
vintagelex
03-05-13 05:22 PM
technol
SC- 1st Gen (1992-2000)
08-09-05 06:41 PM
Nomis
12-08-04 09:10 PM
Quick Reply: Sanding and polishing the headlights
