During Motor Mount Installation, Discovered Leaking Control Arm Bushing
So during my Motor Mount Installation, I discovered fluid leaking from the Driver Side, Lower Control Arm Bushing #2.
After searching on Sewell, I discovered the bushing is sold by itself, w/out the bracket that holds it.
Question:
Is a press require for removal and re-installation of the bushing, any particulars about re-installation, and will it require alignment afterwards.
Thanks
Question:
Thanks
Question:
Thanks
Question:
Thanks
these are oil-filled bushings. wear out around 80-100k due to rubber wearing down with age and use.
i just had mine done less than 5k ago.
yes, yes, yes. you'll have to cut out the metal housing around the pressed out bushing since it usually gets stuck. press out old, cut out old metal ring, press in new. bolt back onto car. alignment is needed.
What were your symptoms if any? Did you notice a change in ride after doing this? Did you do the replacement or paid someone? If so what were the labor cost?
Thanks!
i had my front air struts replaced at the same time. my steering wheel and car who rattle and shake/vibrate over any rough road surfaces. unbearable.
i had an independent lexus mechanic near me do the work. i'm not too comfortable doing that type of work myself. it was pretty straightforward. my mechanic charged 60-70 per LCA bushing for labor. i brought my own OEM bushings. I believe that the price was fair and from what I read a little bit on the lower side. plus a 60 alignment from another shop.
ROCA LCA BUSHINGS QUALITY vs OEM
Having gone OEM with my motor mounts, as i saw no other suitable or worthy alternatives, i stumbled upon these last night in my search for bushings.
Having heard good things about Roca,
Do you think ill be safe with these?
I can get TWO bushings for the price of one OEM, and they recommend changing these in pairs.
No cutting, just press out and new ones press back in. This is a very easy DIY as long as you can bring the 48652 part to a shop who will press it out and in for you. I got my replacements from Sewell with the CL discount. Call around to mechanics or machine shops in your area.
bushings
The bushing has a ridge on the rubber part that has to be oriented in a certain direction.
I don't have it with me, but the repair manual clearly shows this.
I believe the ridge is 90 degrees from the part that bolts to the car, but not sure.
Alan
Alan
I Have done this
I replaced the almost new Lower Control arm Bushings on my IS F. It was very easy providing you have the correct arbor. Took about an hour. You must use a press.
The bushings on the IS F are hard rubber, but because of the OEM specified tow in, cause undo wear on the inside edges of the front tires. Factory tires may wear out in less than 10,000 miles.
The fix is a very hard Thermo Plastic Resin like bushing (TPR) that once installed increases the life of the tires substantially. It also increases ride and handling. I noticed no ill effects.
If the OEM bushings are indeed oil filled, I would not use them. The aftermarket bushings pictured are probably more than adequate and better.
My question is: I used a 3 inch arbor (3 inch piece of steel tubing does the trick) to press the IS F bushings out, what size is needed for the LS 430? I would like to use my old IS F busing (I can get them for almost free) to replace the ones in the LS 430. Can someone measure the OD of the new bushings for the LS 430?
Cronus1995
Suspension and Brakes
08-31-18 06:10 AM
bcorey
01-25-13 12:32 PM
