New Front LCA Bushings Installed
I'm sure there are a ton of post about noises and bushings but I will make my own anyway...
I was getting some popping and creaking sounds from the front end during suspension load stopping and slow driving. For the last few thousand miles I was beginning to hear it. Two of bushes later the popping is gone and she is riding more smooth and planted. Not a drastic difference but noticeable for me as I tend to replace failing parts immediately. Little fanatical sometimes but I have not broken down since starting this preventive maintenance strategy 12 years ago.
Anyway, from my minor research they are the most common as are the castor arm bushings. Those were already done before I purchased the car. The other bushing on the LCA is not a common failure nor are the upper control arms. I think the UCA's tend to last till 200K or more. I'm happy with the feel and it's worth doing if you notice any of the same symptoms. Nothing like a few new bushes after 10 years ad 115k. It really is satisfying. Like a tune up on your suspension.
Link:
http://www.lexussouthatlantaparts.co...865550012.html
Link:
I just replace LCA Bushings, this week end, it takes me about 20 minutes to remove old ones, then I pay 30 $ b to press the new in, and about 30 minutes to install them back , now car feels really good, no more vibration on freeway.
Money spent
150$ for new bushings
30$ for press( at local repair shop)
total 180$
2 hours of time.
Done deal.
Money spent
total 180$
2 hours of time.
Done deal.
Money spent
total 180$
2 hours of time.
Done deal.
Money spent
total 180$
2 hours of time.
Done deal.
Well, I spoke too soon for one of the symptoms. I still have a little pop sound only under specific conditions right when the car is coming to a complete stop and turning. Pretty positive they are the tie rod ends. Probably will replace those soon too. But the LCA bushing replacement has been great.
45460
45470
45460
45470
Just wanted to give an update. The popping I was getting came back because the dealer did not torque down everything properly when doing the LCA bushings. Went back for them to check because it seemed like it was getting worse. They went back and re-torqued it and now everything is great.
Nice I might have to replace my LCA bushings.. when coming to a slow stop it creaks a little bit and also when I fully air up and down real quick sometimes it would creak as well. Really sure its the LCA bushings so I'm going to be changing them out real soon.
so what should i expect the lexus dealer to charge me for this job ? My car has 123k miles on it now and I hear a clicking sound sometimes, usually going slow and sometimes at highway speed too. It's not a very loud sound but it's there. I have a feeling this might be whats wrong.
Really curious
Just curious about the large rear lower control arm bushings.
I have an IS F and removed the stock bushings and replaced them with a much stiffer material to save tire wear. I have a nearly new set and wonder if they would fit my LS 430.
The IS F bushing looks the same and is 3.025 inches OD. What is the OD of the LS 430 bushing?
I'll bet the F bushings are better material or at least stiffer.
Books don't really say, but it would be nice if they interchange.
Kyle Harty
02-08-12 11:21 AM
Banshee365
02-24-10 05:51 PM
SuperCoupe400
Suspension and Brakes
06-02-07 06:42 AM
Lvangundy
30
05-23-06 04:21 PM
