Need help in lower the car with staggered wheels
Old 04-18-14, 07:40 AM
dapimpee
dapimpee's Avatar
Default Need help in lower the car with staggered wheels
I plan to lower my 05 ls 430 about 1 - 1.5 inches with either lower springs or coil, i also plan to run either 18 or 19 staggered wheels set up with it. I have checked with Tirerack and they recommended to have offset of +42 in both 18" and 19 "wheels, however they will not guarantee the fitting if i lower the car. My question is Will i have any problem any problem such as rubbing or so? Love to hear if from every one. Thank you very much.
Old 04-19-14, 09:13 PM
ultm8mind
ultm8mind's Avatar
From what I was told high 20 offsets fit without modification, so you should be fine
Old 04-19-14, 09:42 PM
sr20mofo
sr20mofo's Avatar
if your drop allows the tires to sit flush with the fenders then anything above +35 offset with no more than 9iinch width is fine with no modifications
Old 04-20-14, 01:09 AM
dapimpee
dapimpee's Avatar
Thank you guys. Well the staggered will be 9.5 in the rears so I guess going none staggered will a better bet.
lexi90
10-29-20 12:33 PM
fiuman
05-15-17 08:52 PM
dexterco
07-03-14 12:31 PM
gripau1
05-30-11 09:00 AM
Mesca
06-25-08 07:11 PM
Quick Reply: Need help in lower the car with staggered wheels
