DIY Rear Differential Drain & Fill LS430
Old 10-04-14, 09:07 AM
chunkyda
chunkyda's Avatar
With the guidance of this write-up I did mine today. 177,000 miles and I don't think it has ever been done. I had quite a bit of iron sludge sticking on the magnet but otherwise same simple procedure.
Attached Thumbnails DIY Rear Differential Drain & Fill LS430-diff-plug.jpg   DIY Rear Differential Drain & Fill LS430-diff-sludge.jpg   DIY Rear Differential Drain & Fill LS430-diff-draining.jpg
Old 10-04-14, 06:41 PM
LuxuryGS3
LuxuryGS3's Avatar
Make sure you report back any difference in feel when driving. I guess I need to get on mine. I'm at 111k.
Old 11-18-14, 04:14 PM
writes123
writes123's Avatar
Just performed my first rear diff fluid change after getting one by my mechanic when I got the car 9k miles ago. So, 1st ever rear diff fluid change at 122k and second one at 129k. I observed pretty heavy buildup on the drain plug magnet and the fluid was slightly discolored. Drained out Mobil 1 75W-90 LS fluid and put in 1 qt 75W-140 and 0.6 qt 75W-90, both Mobil 1. I plan on doing another change in 5k miles. At $20 for fluid, I'll change it regularly until the magnet buildup is less. I'd say the last 7k miles are 80% highway miles which may be harder on the rear diff fluid.
Old 02-02-16, 10:48 AM
Mark0106
Mark0106's Avatar
I notice that the oil 75w90 gear oil has a LS (limited slip). 2006 LS430 is not limited slip. Is this oil still OK to use. I wonder if someone has already done some research and found an answer.
Old 02-02-16, 10:59 AM
ryanSC300lover
ryanSC300lover's Avatar
Is the trans and diff diff on the 04+ cars as alluded to previously on this thread ?
Old 02-02-16, 04:01 PM
BradTank
BradTank's Avatar
Everything I came across said that it was fine to use differential fluid with the Limited Slip additive even if the differential was not a limited slip.
I do not think Mobil 1 makes a synthetic gear oil in this weight that does not have the limited slip additive which is why I went looking to see if it was okay to use. I believe on Mobil 1's own web site it says it can be used for both applications.
If anyone finds documentation that says differently, feel free to chime in, but when I went looking for fluid it seemed like the only way to NOT get the limited slip additive was to use a non-synthetic gear oil which seemed like a bad idea since Lexus specifies synthetic gear oil.
Old 02-03-16, 04:38 AM
tradosauru
tradosauru's Avatar
Originally Posted by KawiLex
Yes. Since permanently taking my spare tire out, the back end sits much better and that may have helped me get under there.
Make sure you get the pump for the fluid container just like BradTank showed. . It is the only way to go.
Why would you do that?
Old 03-13-16, 09:51 PM
toantran99
toantran99's Avatar
Just did mine today. 2004 with 144k miles.
Never been done before, when the liquid first came out, it was a silver color. I can see some gold metal shaven in the oil pan.
Car drives the same with the new fluid, can't really tell the different.
Old 03-14-16, 04:16 AM
tradosauru
tradosauru's Avatar
Wow. That's some nasty shavings. Good job.
Old 03-14-16, 07:57 AM
shmi
shmi's Avatar
Originally Posted by toantran99
Slightly off topic I guess but it's cool to me to see the shavings line up along the magnetic field created by the plug. Neat.
Old 08-05-16, 08:30 AM
tradosauru
tradosauru's Avatar
I finished draining and filling the differential on my 2005 LS430 this morning.
Both top and lower plugs took a T-50 bit, not an allen bit. I noticed a bit of metal shavings when I took out the bottom plug (which has a magnetic head).
What was interesting is that when I put the bottom plug back in and took it out a few times I came out with more metal shavings, not a lot but I kept doing it until I couldn't see any more.
I did get about 1.3 qts out. Since I had 2 full bottles I used a little to flush out the differential (having both top and bottom plugs out).
There was no way I could fit under the car without jacking it up so I backed up on ramps and then jacked up the front until the car was level. I removed both plugs with the car only on the back ramps and after draining a bit I jacked up the front. I thought there would be more fluid coming out but not much at all. I think you could do this drain and fill with the rear of the car on ramps.
Attached Thumbnails DIY Rear Differential Drain & Fill LS430-lexus_a.jpg   DIY Rear Differential Drain & Fill LS430-lexus_b.jpg   DIY Rear Differential Drain & Fill LS430-lexus_c.jpg   DIY Rear Differential Drain & Fill LS430-lexus_d.jpg   DIY Rear Differential Drain & Fill LS430-lexus_e.jpg
Old 08-05-16, 09:42 AM
BradTank
BradTank's Avatar
It's an Allen/Hex fastener, this is what a Torx fastener looks like. Star shaped
The Torx bit may have worked, but I would use Allen head.
Old 08-05-16, 09:50 AM
tradosauru
tradosauru's Avatar
The original poster said 10 mm allen bit. I tried it and it wouldn't fit.
Old 08-05-16, 09:59 AM
BradTank
BradTank's Avatar
Well, I'm the original poster and it worked for me. You do have to make sure it seated all the way down. Glad the Torx bit worked for you, but I just didn't want to see someone mess up the fastener on accident.
Here's another write up and its saying its 10mm Allen as well. Maybe the size changed on different years, but its definitely an Allen fastener from the picture you showed.
http://www.lexls.com/tutorials/suspe...iffchange.html
Old 08-05-16, 11:04 AM
jayclapp
jayclapp's Avatar
Seems the manual service schedule doesn't specify the mileage or time when the differential oil is to be changed. It only calls for an "inspection" every 15,000 miles. They don't tell you what the "inspection" entails. Clearly they expect the dealer service tech to make the call on when to change. I changed mine at 50,000 and 90,000 miles. I am approaching 120,000 currently and will probably change at 140,000 to 150,000 miles.
Quick Reply: DIY Rear Differential Drain & Fill LS430
