2003 LS430 - Front Washer Sprayer Stopped Working
Old 12-17-13, 06:13 PM
Arcturus
Arcturus's Avatar
Default 2003 LS430 - Front Washer Sprayer Stopped Working
Hello,
We are getting well into the Quebec winter here and it has been around -15 to -20 degrees C for the past week or so.
A week or two ago I noticed that fluid wasn't coming out of one of the nozzles, then the spray kept getting weaker and weaker and finally nothing came out. thought it was low on fluid so I filled it up. Now they don't work at all.
They nozzles looked like they had iced up, so I cleaned them out and tried again, but nothing. When I press the button on the stalk I don't hear anything now.
Does this sound like ice in the system? Or has my washer motor quit. Need help.
Thanks!
Old 12-17-13, 06:45 PM
AlexusAnja
AlexusAnja's Avatar
Probably washer motor... mine on '99rx went and it was $90 part and $100 labor. Private mechanic.
Old 12-17-13, 08:52 PM
Arcturus
Arcturus's Avatar
That's what I'm thinking. It sounds dead as a doornail.
Anyone have a walkthru to replace it?
Old 12-18-13, 05:08 PM
Arcturus
Arcturus's Avatar
In the morning today I tried to use the sprayer with the door open and I could hear the motor running. So okay it's not the motor. I kept using the sprayer over and over again and eventually the fluid came out. So now it works again, PHEW!
Maybe it was combination of air in the system and the system icing up. Nice to know repairs aren't needed. Just got the car.
Old 09-01-14, 07:14 PM
Arcturus
Arcturus's Avatar
Make sure to get a good washer fluid that resists the cold weather. Seems the one I bought ices up in very cold weather. Nothing was wrong with the system at all.
I also had problems with clogged washer nozzles. I found an opened-up paper clip worked really well at dislodging the blockage. I am happy to say I have full washer capability without having to replace any components.
need2boost
SC- 1st Gen (1992-2000)
02-14-10 01:13 AM
TheBigGuy
17
02-21-09 12:26 AM
JZCHAOS
RX - 1st Gen (1999-2003)
17
10-13-08 07:09 AM
jeffyjeff
01-19-07 01:35 PM
dbullen
Maintenance
05-15-06 10:57 AM
Quick Reply: 2003 LS430 - Front Washer Sprayer Stopped Working
