Beware! Ebay Aisin Water Pump Fails After 5 months!
Old 12-23-13, 07:06 AM
  #31
jimbosr1
jimbosr1's Avatar
i ended ip getting the water pump and timing belt from my local toyota dealer for $196 and i bought a tensioner and having the toyota dealer install them for $650.changing them as we speak.
Old 12-31-13, 05:09 AM
  #32
99LSBrad
99LSBrad's Avatar
UPDATE: Returned pump and belt. After inspection was issued full refund by seller.
Old 01-12-14, 08:59 PM
  #33
BT3100
BT3100's Avatar
Originally Posted by LScowboyLS
Aisin (the Toyota water pump OEM) doesn't make "faulty pumps", however a counterfeit Aisin pump from China is a real possibility.
I have to jump through all kinds of hoops to buy ECU capacitors that are genuine Panasonic, Rubycon, Nichicon and Chemi-con by going through only factory authorized sources, due to the same rampant counterfeiting.
Always buy your Aisin kit via an authorized Aisin aftermarket dealer - you can contact Aisin to see if a seller is genuine by contacting:
Aisin USA Mfg., Inc.
1700 East Fourth St.
Seymour, IN 47274
(812) 523-1969
Tell that to the pump that failed at 70,000 miles on my wifes Sequoia
All companies make faulty pumps at one time or another. Bad runs, poor materials etc.
Old 01-21-14, 01:24 PM
  #34
damon
damon's Avatar
Just ordered TKT-021 kit from Aisin.. Have found RockAuto to be Honest over the years.
Old 01-21-14, 08:09 PM
  #35
Tom57
Tom57's Avatar
Strongly suggest you change the T-stat when doing TB / WP. Lexus dealers don't always have the T-stat on the parts "menu" for TB / WP overhaul. It's a $20 part that has a rubber gasket seal that DOES deteriorate in the hot antifreeze over time. It's a hassle if it needs to be replaced later, and your engine won't reach operating temp, or worse, it overheats.
Old 01-21-14, 08:56 PM
  #36
jimbosr1
jimbosr1's Avatar
on these models the t-stat is really easy to change out.for those that are not inclined, good advice.
Old 01-22-14, 07:16 AM
  #37
Tom57
Tom57's Avatar
T-stat is very easy to replace. Preventive maintenance is even easier, IMO. If it goes bad at an inconvenient time / location (on the road), that's not pleasant. It's only a question of when, not if, it will go bad.
Old 01-22-14, 10:23 AM
  #38
jimbosr1
jimbosr1's Avatar
i am a firm believer of staying on top of maintenance sense working on aircraft.however i have never had a t-stat fail in the closed position and i have owned nearly 40 autos.my 86 mr2 has the factory t-stat and water pump but i change every thing else at half the require maintenance schedule.
also change the rad cap every 30k miles.i can change the t-stat in under 30 minutes so for me its not a big deal.
Old 01-22-14, 10:47 AM
  #39
Tom57
Tom57's Avatar
In cold weather climates like here in Chicago, stuck open is a big problem in winter - as it was for me this winter - since the engine never reaches operating temp. Little to no heat. Can't defrost windshield / side windows. If you can see out the windows, you freeze while driving. I'd hate to have it stuck open on a trip to / from Michigan. Georgia looks pretty good right about now!
Old 01-22-14, 02:59 PM
  #40
jimbosr1
jimbosr1's Avatar
you are right we dont have that nasty cold salty slop in ga,i had that in maryland and south dakota. i guess you can tell i dont miss that.
Old 10-08-15, 07:30 PM
  #41
123go
123go's Avatar
I never saw one fail early yet. Maybe pumps fault but again maybe not?
Most times we jump on the newer water pump being the "problem" when this happens, but it may be "caused" by other issues.
Its a closed system so If the radiator cap seal fails or there's a leak in the system where the system fails to produce enough pressure it can happen. Without pressure building up high enough from the water pump pressurizing the system correctly just over a short time even a newer pump seal will deform and pump failure will occur. Its very common for older cars pumps to fail back to back just from their radiator cap seal going bad over time. The owner fixes the problem but not the cause of the problem so it bites us again.
Yrs ago I had a 91 4cyl pickup drive me nuts over a yr.
2 water pumps,1 radiator, 2 thermostats then I finally learned its my cap.
Hey' I didn't change the head gasket and heater core..lol Had I just done my pressure test sooner I'd knew it was my cap.
Needless to say I do change the cap every 100k or with every pump failure now.
I have to think by removing our radiator caps less the seal will turn hard & dry rot more, out of sight out of mind thing?
Just a thought since we used to remove them much more.
Last edited by 123go; 01-13-21 at 05:11 PM. Reason: My truck not our car done this Yrs ago. Damn I'm old..lol
Old 10-08-15, 08:47 PM
  #42
semar
semar's Avatar
another reliable parts supplier is Autohaus Arizona.
Deal with them for over 10 years, Never a problem
Old 10-11-15, 09:28 PM
  #43
PersianOne
PersianOne's Avatar
I ordered the same kit off Amazon and now I am scared lol!
Old 01-23-20, 02:29 PM
  #44
BryanJ
BryanJ's Avatar
Ordered a kit From EBAY from a well known seller!!! Won't say who but letters are TL. Brand new water pump is leaking from the Vent tube!! Maybe one of those Chinese knock offs!! So now to order hopefully good Asin from Rockauto. Top it off, all "new" 3 seals are seeping!! So I'm wondering when my 4runners mitsuboshi belt is going to break. So will change out before 60k. I've learned my lesson.
The following 2 users liked this post by BryanJ:
Margate330 (01-23-20), spuds (10-18-20)
Old 01-23-20, 03:20 PM
  #45
Margate330
Margate330's Avatar
Thank you for saving me the heartache!
I was thinking about ordering the Asin kits on ebay to have on hand to do the Tbelt/WP service this year and
after reading this I will bite the bullet and order from my local Lexus dealer.
PS- To be honest I been wondering if those Asim WP's flooding all over on ebay were knock offs too.
Quick Reply: Beware! Ebay Aisin Water Pump Fails After 5 months!
