how to turn off vsc
Old 12-10-13, 10:51 AM
seve7
seve7's Avatar
Default how to turn off vsc
is there a way to disable the vsc on our cars? the manual says the traction button turns off the traction control and vsc, but its actually leaving the vsc on, kind of annoying actually in the snow.
Old 12-10-13, 11:21 AM
Lavrishevo
Lavrishevo's Avatar
The button is right in front of the gear shift. Says Trac Off.
Attached Thumbnails how to turn off vsc-lexus_ls_430_ultra_luxury_interior.jpg   how to turn off vsc-lexus-ls430_2004_800x600_wallpaper_14.jpg
Old 12-10-13, 11:29 AM
GLIDESUL
GLIDESUL's Avatar
2001-2003 has vsc on/ off button 2004-2006 has trac button but it useless for wheel spin.
Old 12-10-13, 11:58 AM
seve7
seve7's Avatar
im saying when i turn the trac off, the traction control actually turns off, but the vsc stays on. my car is an 06. its pretty annoying coming from years of driving rwd sports cars without any driver aids.
Old 12-10-13, 01:16 PM
Lavrishevo
Lavrishevo's Avatar
So you are saying the VSC light stays on at all times? If so, you have another problem that is causing this.
Old 12-10-13, 04:58 PM
seve7
seve7's Avatar
no, when i switch the traction control off, the traction control turns off, and the trac off light comes on. according to the manual, turning the trac off should also turn the vsc off, but when the car starts to slide, it starts regulating the brakes and tries to keep it on course. im just curious if its possible to turn this all the way off.
Old 12-10-13, 08:01 PM
KING
KING's Avatar
I understand what you're trying to say. Simply you want none of the safety systems to kick in on you automatically when the car is drifting.
I have thought of this question myself a lot. I don't remember getting an answer. But I do remember someone talking about removing a fuse, and that disabled the whole system, so you can drift and do donuts like you'd do on a normal sports car with the traction off.
I hope someone has an idea, as I myself am interested to know.
Old 12-10-13, 11:42 PM
seve7
seve7's Avatar
i figured that was what it was going to take, but im assumed that it throw a light, which i dont want. i'll try pulling some fuses and figure it out tomorrow.
Old 03-12-21, 04:20 PM
RiskyFisky
RiskyFisky's Avatar
Default Was this ever figured out?
I have the same problem in my 2004 ls430
Old 03-15-21, 03:57 AM
BigBoomer
BigBoomer's Avatar
There is a sensor under the center console that detects acceleration in all directions.
You can disconnect that sensor and it will throw a VSC warning, but will then let you drift if you switch off the Traction control.
On mine, when I reconnected it I had to shut down the car and restart it for the VSC warning to go away, but the ECU retained the error code.
I guess you could fit a switch somewhere to enable/disable this sensor.
Did you switch the mode switch to "Snow"?
Spinning tyres ain't gonna do much in the snow, not that a heavy rear wheel drive car is an ideal snow vehicle at any time.
Old 03-15-21, 03:12 PM
02Legend
02Legend's Avatar
Will need to use Google translate or something else.
https://minkara.carview.co.jp/smart/...1786/note.aspx
BigBoomer (03-16-21)
Dezoris
RC - 1st Gen (2015-present)
07-17-15 12:46 PM
Kazabet
11-20-13 12:30 PM
teoh2005
IS F (2008-2014)
58
01-18-12 10:44 AM
Dble Agent
IS F (2008-2014)
13
03-16-09 09:23 AM
intls
31
01-25-08 03:47 AM
Quick Reply: how to turn off vsc
