2001 ls430 driver mirror problem
Old 09-09-13, 04:52 PM
69charger
69charger's Avatar
Default 2001 ls430 driver mirror problem
Driver's side mirror is making noise (mirror motor winding noise) after starting car, 6-7 seconds. What could be the problem; is it in the mirror itself, in the mirror control unit inside the door or in the mirror switch on the dash (used to control mirror tilting? Any suggestions are appreciated.
Old 09-09-13, 06:31 PM
BMW7_LS430
BMW7_LS430's Avatar
Is it the mirror folding or glass adjustment motor?
Old 09-10-13, 03:53 PM
69charger
69charger's Avatar
I believing it is the mirror trying to fold in or out. Would u know if there is a small motor in the mirror?
Old 09-10-13, 06:45 PM
BMW7_LS430
BMW7_LS430's Avatar
yes, there is a small motor in the mirror. check if the threaded shaft is engaged with the mirror . Sometimes it can get disengaged and then the motor will keep spinning but won't pull the mirror back. You can push on the mirror and try to use mirror movement buttons at the same time.
francis123
07-12-14 04:04 PM
lexus93257
08-25-11 08:20 AM
irokdastar
04-21-11 01:56 PM
JCW
02-26-06 05:54 PM
Quick Reply: 2001 ls430 driver mirror problem
