Lexus over filled my oil
Old 06-02-13, 04:56 PM
55excl
55excl's Avatar
Default Lexus over filled my oil
They over filled my oil by about 1 quart will this damage the motor?
Old 06-02-13, 05:37 PM
Kansas
Kansas's Avatar
I sure wouldn't drive it. I would "flat-bed" it to the dealer at their expense.
Old 06-02-13, 07:22 PM
Dawa
Dawa's Avatar
they "should" know the oil capacity of your motor.
either they were being complacent
or they might not have replaced the oil filter, which again is a problem
as a new filter is more important than new oil.
when you remove the filter it retains oil, idk about the size of your filter but
on one of my vehicles the capacity of my filter is half a qt.
that still wouldnt be an excuse to overfill it by a whole qt, but would identify
another problem.
the problem with TOO MUCH oil is that it flows up to the crankshaft, which, upon
contact aerates the oil, turning it into mist rather than liquid, so that it cant be pumped
through the system. how do you know its over 1 qt. if its at the top/high line, youre good.
Old 06-03-13, 12:36 AM
55excl
55excl's Avatar
another problem.
It is just as high over the full line to the low line.
Old 06-03-13, 07:27 AM
jimbosr1
jimbosr1's Avatar
this is another thread on why you should do your own oil change if you are healthy enough to do so.
Old 06-03-13, 08:54 AM
Dawa
Dawa's Avatar
im sorry i dont understand can you try to reword that for me please
Old 06-03-13, 08:59 AM
Joeb427
Joeb427's Avatar
I think he means the same gap over the full line as the gap of the low to full line.
Old 06-03-13, 01:51 PM
55excl
55excl's Avatar
Rite.1 inch over the full line.
Old 06-03-13, 02:27 PM
Lust4Lexus
Lust4Lexus's Avatar
It's probably not a huge deal, but it would bug me. Bring it back and tell them to properly refill.. You don't just haphazardly throw in 6 quarts.you put in 5 and the slowly add until you hit the top mark. I'm sure they will take care of you. Just bring it back. I don't think the car will explode by driving it to the dealer. Good luck.
55excl
55excl's Avatar
Ok called Lexus they said it was ok. They said if there was a problem you would know about it. I went to toyota because lexus is a hour away toyota is 2 miles away they said I did no damage but they wanted to change the oil any way even though it only had 1K on the oil. I had them change the oil they said it was 1 1/2 quart too much oil. I have this documented in case there is a problem. I just got this car 6 weeks ago from lexus with 1 year warrenty from lexus it has 27K.
Old 06-03-13, 02:30 PM
jimbosr1
jimbosr1's Avatar
sounds like the lexus dealer owes you a free oil change.
Old 06-03-13, 02:37 PM
warminwisc
warminwisc's Avatar
So the same Lexus dealer that overfilled it 1 1/2 quarts told you it was OK to be overfilled? WOW what idiots. I guess Jimbosr1 has a good point but I will just check my oil after a change from now on.
I left my Yota dealer for Lexus last oil change they will do a stright forward Mobil 1 change and filter for 75 bukcs but i guess I gotta check up on em.
Old 06-03-13, 02:57 PM
55excl
55excl's Avatar
I dont know what made me check the oil last nite I just bought a used car from the lexus dealer 6 weeks ago but I am glad I did. I always check my oil after an oil change but I did not after buying it from lexus.
Old 06-14-13, 06:38 AM
Tmarbury
Tmarbury's Avatar
55ecl,
I would write a letter to the service manager at the dealership and ensure that they are aware that you will be sending a follow-up letter to Lexus HQ's.
Old 06-14-13, 03:16 PM
55excl
55excl's Avatar
Originally Posted by Tmarbury
55ecl,
The Toyota tech said I did no damage the minute he saw the car with out checking the oil then he checked the oil and said it was high. The Lexus dealer said it would not damage the motor. If I have proof that Toyota said it was 1 1/2 quart high I think that is good enough if anything happens due to this. What is Lexus HQ going to do?
Quick Reply: Lexus over filled my oil
