Tail-light bulb replacement?
Nope not yet. I was told by Paul @ Lextech that the assembly has to be replaced so I just took his word for it... But having a hard time believing that it's not just a simple bulb that can be replaced...
Is it possible?
Is it possible?
What year is your car? Guessing its an 04~06 with the factory LED tailights. If thats the case I do believe there are no serviceable bulbs besides the reverse and blinker. See pic.
Pretty sure the LEDs are built into the housing. Although I would take a look as it could be a bad connection and nothing needs to be replaced. I find it a little hard to believe there would only be one LED in that location and that all of them would go out at the same time.
Paul said the oem part was over $100... so I told him I could live with the 1 light being out for a while... actually at that time, the light would work at times, and not work certain times... Sometimes it would also be a little dimmer than the others..
Perhaps this does mean it's a loose connection?
Have you figured out the problem?
I'm having issues with my right rear tail lamp piece. Sometimes the top LED row will go out, sometimes the bottom, and sometimes the entire side. My friend the other day told me it flickered sometimes when he was following.
I'd hate to have to replace it and then have the same issue on the other three tail light pieces..
