Banging sound and vibration from steering wheel
Old 04-18-13, 02:40 PM
Rowdiggty
Rowdiggty's Avatar
Default Banging sound and vibration from steering wheel
I hear and slightly feel a banging sound when I go over decent sized bumps. It seems to be coming from part of the steering assembly. The wheel and column feel solid but I can feel the slight vibration coming from the steering wheel.
Any ideas or anyone experiencing the same thing?
Old 04-29-13, 10:29 PM
DSRxGOOMPA
DSRxGOOMPA's Avatar
im experiencing the same problem right now. have you found the cause of this problem?
Old 05-19-13, 01:01 PM
Rowdiggty
Rowdiggty's Avatar
I havent. It seems to happen the most if I have to come to a quick stop and the road is fairly rough. any luck?
Old 05-19-13, 01:21 PM
jimbosr1
jimbosr1's Avatar
may be your motor mounts going bad?
Old 05-19-13, 01:43 PM
yuri.ber
yuri.ber's Avatar
Steering rack bushings need replacing most likely. I had the same issues especially when wheel were turned.
Old 05-19-13, 02:18 PM
Rowdiggty
Rowdiggty's Avatar
That makes sense I think I'll start here.
Old 05-19-13, 05:53 PM
Lynzoid
Lynzoid's Avatar
there's 3 cv joints in the steering shaft... you should replace at least 2 of these (lower and middle) if nothing helps
Old 05-28-13, 11:15 PM
DSRxGOOMPA
DSRxGOOMPA's Avatar
any lucky with resolving the problem? i recently changed both my upper control arms cause there was play in them and it made the problem a little less noticeable. but its still there when i hit a really big bump.
Old 06-03-13, 01:36 PM
Sentinel
Sentinel's Avatar
I have the same issue. My steering has never been quite right on this car. Lexus replaced my lower control arms it was much improved but the noise is still there.
I replaced the steering bushings when i first got the car.
Old 06-07-13, 05:12 PM
malrafe3i
malrafe3i's Avatar
ys guys i hve the same problem especially whn riding between 80-100 km ny way i chnged upper arm
lower arm bush. links n yet same problem any video to guide ys chnge the bushes n w clearifying video for the cv joints mention above plz
Old 06-07-13, 08:51 PM
kenshimoto
kenshimoto's Avatar
i had vibration on my steering wheel before...i retorque the wheel and the vibration is 95% gone. i never use impact gun on my wheels even tho it makes the job faster
Old 06-08-13, 11:09 AM
pibob
pibob's Avatar
I had a problem like you stated. It turned out to be a loose alignment nut. Had the nut tightened and alignment and all is good. Everyone kept telling me it was control arm bushings. Not
Old 06-09-13, 02:09 PM
KING
KING's Avatar
This is one of the very common problems in the LS430. And it just happens by time.
Th secret to getting it feeling firm and back like OEM again, is to change "a part right behind the steering wheel" ( I'm sorry I don't know the exact name in English, but I'll try to describe it.)
It is located right behind the steering wheel, it connects the steering wheel with the front wheels. It's like an adapter.
It's circular in shape and has about 4 bolts if I remember correctly.
I'm sorry I couldn't provide the name. But I'll be happy to help you more if you PM me.
Good luck!
Old 06-09-13, 02:59 PM
jimbosr1
jimbosr1's Avatar
is it called a steering knuckle.?
Old 06-10-13, 11:56 AM
Sentinel
Sentinel's Avatar
http://www.lexussouthatlantaparts.co...ze/452341B.jpg
Which part on this diagram?
L3XUSFAN
ES - 6th Gen (2013-2018)
12
01-27-19 09:50 PM
Panerai127
06-19-12 08:59 PM
B43088
12-21-11 04:38 PM
sc400123
12-12-08 01:59 PM
Lexusfreak
02-11-04 01:02 PM
Quick Reply: Banging sound and vibration from steering wheel
