How do I show the mpg reading on the dash?
Old 04-16-13, 07:16 PM
Dispin
Dispin's Avatar
Default How do I show the mpg reading on the dash?
I saw this and I'm wondering how I do this on mine. It's an ad from the same year so I assume there is a way. Would be really nice to see the mpg while driving.
Old 04-16-13, 07:20 PM
Dispin
Dispin's Avatar
Ok after looking closer at the dash I don't think I have the compass or the other screen
Old 04-16-13, 07:27 PM
yuri.ber
yuri.ber's Avatar
On the right on your steering wheel you'll find Disp 1, Disp 2 and Reset buttons.
Disp 1 is the button you need, press it and a left display (under the tachometer) will show approx range in miles, current MPG, average MPG, average speed, miles driven on tank etc.
Old 04-16-13, 08:19 PM
Dispin
Dispin's Avatar
That's interesting! I noticed a couple days ago that display 1 and display 2 do nothing. Maybe I have a fuse out? I'm going to try and play around with it and see if I can get it to work.
Old 04-16-13, 08:29 PM
AlexusAnja
AlexusAnja's Avatar
that particular photo, the compass is only there for non-navigation equipped LS430s. If you have the nav, the compass is then relocated to the center dash. I have the CL trim, so when I press Disp1 on right side of steering wheel, it toggles through the various trip items. Disp2 only changes the cruise guidance distances.
Old 04-16-13, 08:30 PM
tcr101
tcr101's Avatar
On my 01 (no navi, no ml), Click and hold Display 2 to change the middle display between "Compass" to "Outside Temp" and to display nothing.
Old 04-16-13, 08:32 PM
Gene01
Gene01's Avatar
Unfortunately, the compass is not displayed on cars that have Navigation.
Old 04-16-13, 08:52 PM
Dispin
Dispin's Avatar
Unfortunately this one doesn't have Nav but it was the only local pearl white for sale.
So I definetly have the display section but even after turning the car running and holding down display 2 for 10 seconds, holding it off and on for 3 seconds, holding all 3 buttons, etc. I couldn't get it to display anything. I did hear a beep the first time I help display 2 after around 10 seconds. Is this a common issue?
The car is stock, the flashlight made the gauges look blue.
Old 04-16-13, 09:09 PM
tcr101
tcr101's Avatar
Thats odd nothing is displayed. Display 1 should change just by pressing the button (>1 second). I would guess you have a fuse out or something is wrong with the display itself.
I have ~225k on mine and all the electronics still work. Might wanna have the code pulled for your CEL
Old 04-17-13, 09:21 AM
Gene01
Gene01's Avatar
If it turns out not to be a fuse, I would look at the switch itself or the wiring between the switch and the display next.
Old 04-17-13, 02:52 PM
Dispin
Dispin's Avatar
Urgh, guess it's not a fuse. I pulled 22 which is a 7.5 from the passenger side fuse box and it was fine. I even swapped it for a 7.5 from another can and still nothing. I have no clue where to start to fix this.
Also, there is no check engine light on. I had the key in the accessory position for the picture.
Old 11-02-23, 07:35 PM
Lsjay
8th Gear
Lsjay's Avatar
I’m having the same problem not little mini Lexus screen nor no distance tracking and I I have the non navigation.
out2wn
ES - 6th Gen (2013-2018)
09-24-14 02:50 PM
alpinefun
03-12-14 05:46 PM
markwill12
07-22-13 05:49 PM
Frank1934
05-08-13 08:03 AM
mir
08-27-07 03:20 PM
Quick Reply: How do I show the mpg reading on the dash?
