Double Pane laminated UL glass?
My 2001 LS430 UL has double pane laminated glass. My drivers side window is going to need to be replaced due to some cracks.
Does anyone know if Toyota's replacement glass is still double pane laminated?
The part number I have found is: 68102-50180
http://www.lexuspartsnow.com/parts/l...102-50180.html
Don't know about that part number, but only CL and UL trims had the double glass laminated glass. All the lower trims had single glass so you will have to make sure. I would contact the seller.
