Door not unlocking
Old 11-13-12, 02:23 PM
Cronic
Cronic's Avatar
Default Door not unlocking
The front passenger door on my 05 UL is not locking/unlocking intermittently. It is not totally dead at this point,.
I am wondering if there is a way by symptoms to diagnose if this is a problem with the actuator or "cables"? Or is taking it apart the only way?
Any help is appreciated.
Old 11-13-12, 05:38 PM
Randy B
Randy B's Avatar
Default Highly doubt its the rods.
You don't have cables. More than likely the actuator motor is dragging, the beginning of total failure of the motor.
Randy B
Old 11-14-12, 08:45 AM
Cronic
Cronic's Avatar
Randy B
Thanks. I was under the impression that there were cables that connect to the actuator, and they stretch/break.
Looks like a pretty expensive part. :/
I guess I'll order the part. Is it a pretty straight forward install?
Old 11-15-12, 07:05 AM
milesdf
milesdf's Avatar
My driver side door repair cost 790 dollars at the Lexus dealer.
Old 11-15-12, 03:44 PM
Cronic
Cronic's Avatar
Ok, a bit of an update. If I walk up to the door with the key in my hand it will unlock from the outside. But if I hit the unlock button from the driver seat it wont unlock.
Does this still sound like an actuator?
I guess I am not understanding why it would unlock from the outside by touching the handle, but not inside.
Old 11-15-12, 04:14 PM
Randy B
Randy B's Avatar
Default Try the passeger door lock switch.
If it unlocks from the passenger door switch at will, then it sounds like your door switch on the driver's door is shot. My gut still goes with the actuator and you are catching it working intermittently.
Randy B
Old 11-15-12, 05:18 PM
Cronic
Cronic's Avatar
Randy B
The driver door opens every other door though..
I need to try the passenger side switch when my wife gets home.
I think you are right with the actuator though.
Old 11-15-12, 07:40 PM
LEX ES300
LEX ES300's Avatar
My passenger side front door lock stopped working on my 2004 LS430 a few months ago too. I live in Australia so the passenger side is on the left for me. It started off slow then got progressively worse until it wouldn't lock anymore with the remote and car wouldn't beep on locking.
Sadly in Australia, parts are not cheap and there's only 1 Lexus dealer in my entire state!! Lexus took the door apart and quoted me $1400 and stated I needed a whole new door closer assembly and actuator - the Australian part number was 69040-50220 which is only for RH drive vehicles and the part number was also for a series of parts. I was so shocked, I tried to seek help overseas from Lexus dealers and club vendors, but sadly either none could supply the part (due to LH vehicles) or even reply to my emails!! . Tried to get the part direct from an export company in Japan, but with postage and duty it was going to cost $900 just for the parts then I would have had to pay Lexus to install it anyway.
In the end I ordered it from the only dealer in my state and negotiated the total cost down to $1070 I couldn't risk taking it all apart and breaking something else, plus I didn't have the time and if something went wrong with a part I supplied myself then they wouldn't honor any warranty etc.
Good luck with yours, hopefully it will be cheaper to fix than mine was.
Old 11-16-12, 08:37 AM
Randy B
Randy B's Avatar
Default Ahh, so the driver switch does work.
If it works on the three others regularly, your actuator is dying. If you are familiar with small electric motors, the brushes are wearing on the armature. Sometimes they work, other times they don't. The motor will fail here shortly. Truly sorry to be the bearer of bad news. It's not a fun job at all.
Randy B
dbogotti92
07-16-19 09:22 AM
BostonIS
04-19-16 08:16 AM
ZeekGS300
04-20-07 07:36 AM
bLingIn3o0
12-15-04 10:28 PM
GammaLex
05-29-04 03:04 PM
Quick Reply: Door not unlocking
