Will ES350 wheels fit 03 LS 430?
I have been thinking of putting ES 350 chrome wheels on my 03 LS 430
Here are the specs from the Vendor:
WHEEL SIZE: 17x7
WHEEL OFFSET: 45
BOLT PATTERN: 5-114.3
HUB SIZE: 60.1
BACK SPACING: 5.77
My current tires are 225/55/17
I was hoping someone could confirm they have put these on, as i know the large calipers for the LS has been an issue with many of the aftermarket rims I have been looking at.
If someone has pics of these rims on their LS in any finish, please post I would be very thankful
Also is there any safety concern in going to a 7" wide rim from 7.5" width
TIA
WHEEL SIZE: 17x7
WHEEL OFFSET: 45
HUB SIZE: 60.1
BACK SPACING: 5.77
TIA
sadly i have heard many rims with the same bolt pattern and offset wont fit the LS due to our massive calipers.. can any one else confirm the fit. i would hate to order these and be stuck with having to ship them back cross country
Super Moderator
You would have to try them on and see. When I looked at some, I thought there may be sufficient clearance but one cannot judge based on the caliper distance of the ES, what looks to be good may be 1/8-1/4" no-go on the LS.
The rim width is fine and nominal for the 255/55, if you go wider on that rim, the sidewall will bulge.
wcoastls
26
05-02-11 09:51 PM
uae
08-24-10 02:25 PM
whalenpl
03-09-06 07:53 PM
