Help!..Mirror motor wont stop!
Old 10-22-12, 08:39 PM
gbracer04
gbracer04's Avatar
Default Help!..Mirror motor wont stop!
How do I fully disable the passenger mirror motor that controls the folding. I already tried unplugging it from the button on the dash and that didnt work, Everytime i start the car the gear strips and winds. Im trying to prevent further damage till i get it fixed.
Thanks, Anyone??
Old 10-22-12, 10:43 PM
stemirra
stemirra's Avatar
Originally Posted by stemirra
Hi,
Here is a different fix for this over rotation of the outside side view rear view mirror issue. This one is easier, will make it look and work like new. It solves the same problem another way with much less butchery. I am" very" surprised that this fix has not gotten more attention on this form due to it's frequency of occurrence, outcome, ease or repair and cost.
https://www.clublexus.com/forums/ls43...-05-cents.html
Posted from ClubLexus.com App for Android
Old 10-23-12, 01:37 AM
gbracer04
gbracer04's Avatar
Thanks for replying. I noticed the attachment page is not found. Is there another page? I just wanna kill the power to it for now. Do you know how to do that?
Old 10-23-12, 05:34 AM
gs4bkny
gs4bkny's Avatar
did you try pulling the fuse?
Old 10-23-12, 05:59 PM
gbracer04
gbracer04's Avatar
Where is the fuse located?
Old 10-23-12, 06:11 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Reset the ECU see if it will cease. (remember, search before you post. )
Old 10-23-12, 06:49 PM
gbracer04
gbracer04's Avatar
I searched posts and i could not find a thread about resetting ECU. I dnt even know where it is. The search engine for this site is not very accurate. This is prob why people repeat threads all the time. Could you please help me by pointing me in the right direction. I have a 2004 LS 430 with 65K miles. I just want to cut power to the motor folding mechanism or try resetting it. Im trying my best to find answer and I been searching tons of threads. Im not very familiar with the car but im trying to learn.
Thanks!
Old 10-23-12, 08:19 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I myself don't even use this site to search for threads because it's not accurate. I just search it up on the internet.
EXE: bucking and surging Lexus. Just put Lexus at the end and Club Lexus or Lexus owners club will pop up.
To reset the ECU, all you have to do is disconnect the negative battery terminal for a couple minutes. In so doing, this makes the vehicle have to re learn it's set-up factory procedures. Hopefully this will stop the problem. GL!
Old 10-24-12, 01:18 AM
gbracer04
gbracer04's Avatar
Thanks I will give that a try!
Old 10-24-12, 08:01 PM
gbracer04
gbracer04's Avatar
Ok so I tried unplugging batt to reset ECU and that didnt work. Then I unplugged the fuse that controls the motor and that worked but it kills all power to the passenger door, (door lock, window, lights, etc). So I guess I will have to manually unlock the door buy hand and not use that window for a while. Oh well I guess its better than causing more damage in the long run. Thanks to everyone who helped me find a solution!..
Damian@FI
07-15-19 05:02 PM
ALBINO
08-10-13 05:16 AM
DrDan
RX - 1st Gen (1999-2003)
04-23-12 02:24 PM
jp350
06-13-08 12:08 PM
Jackco711
11-18-04 01:26 PM
Quick Reply: Help!..Mirror motor wont stop!
