Tail lamp not working
Old 09-11-12, 10:30 AM
TallerMike
TallerMike's Avatar
Default Tail lamp not working
So the "Tail Lamp Failure" light came on recently and I discovered that my drivers side rear upper (above the reverse light) bulb was out. I changed the bulb with a spare bulb I had and it still wasn't working so I bought a new package of bulbs and still no go. I confirmed with a 12v source that the replacement bulbs are working, so I know it's not that.
I looked at the socket and wires with a flashlight and didn't see anything unusual. I also looked for a fuse that might control that one bulb (unlikely, I know), but came up with nothing.
Any thoughts?
2001 LS430 UL
Old 09-11-12, 12:49 PM
john339
john339's Avatar
Should not be a fuse for one tail light.
Did you use a Lexus bulb to replace the bad one? There was a thread here saying the correct bulb is a must as the car thinks a different bulb means a bad bulb.
Old 09-12-12, 08:28 AM
yuri.ber
yuri.ber's Avatar
Make sure you bought the right bulbs. Top and bottom bulbs are different. I usually get them from autozone.
Old 09-12-12, 08:30 AM
TallerMike
TallerMike's Avatar
So it turned out that I was looking at the wrong bulb. I had pulled out and replaced the blinker but it was the little bulb as yuri.ber noted.
PL372
RX - 3rd Gen (2010-2015)
05-04-15 11:39 AM
chuckli
07-20-10 01:54 PM
mmatheny
04-04-09 06:40 PM
ArmyofOne
Lighting
03-23-05 08:49 PM
roberttran
Lighting
05-24-04 07:50 PM
Quick Reply: Tail lamp not working
