Broke left rear gspeaker (actually air purifier) grille next to sub woofer 01 LS430
Old 07-31-12, 09:16 PM
stemirra
stemirra's Avatar
Default Broke left rear gspeaker (actually air purifier) grille next to sub woofer 01 LS430
I am so stupid. I wanted to see if the speaker on the rear package shelf (drivers side) next to the sub woofer was working because I could not hear anything coming from it. So I pull off the grille/cover and break one of the tabs off the cover only to learn there is no speaker there at all. I read up on this site and now learned it is to the rear air purification system. I cleverly re-built the damaged clip and re-attached the grille after learning the replacement cover is $135. Looks great, tight as can be. Only question is about the little piece of plastic that got lost in there. I do not hear it rattling around (very small) but does anyone know how I can retrieve it? I am concerned that it may eventually make it's way down to the blower motor and cause a problem/noise or do you think it will just settle into a ridge somewhere in the duct and never be a problem and I should just forget about it. Please advise. Thanks.
Old 07-31-12, 11:07 PM
HiloDB1
HiloDB1's Avatar
Take out the filter for the rear A/C in the trunk. It probably fell into there and got stuck.
Old 08-01-12, 07:29 AM
john339
john339's Avatar
vacuum? lift the grill and use a heavy duty shop vac?
chromedome
ES - 6th Gen (2013-2018)
03-03-18 04:28 AM
Goochie
GS - 1st Gen (1993-1997)
08-06-12 05:27 PM
SC30096
04-30-07 05:55 PM
caliness
09-03-04 02:05 PM
Quick Reply: Broke left rear gspeaker (actually air purifier) grille next to sub woofer 01 LS430
