bc coils
bc coils
just finished putting on bc coilovers and i cant get the rear to go lower. I have adjusted the rear coil to its lowest point and this is where she sits at. Did i install the coilover wrong? i thought i would be able to go lower than this. the front has no problem going lower.Is it possible to put the rear coils on the front by accident?
just finished putting on bc coilovers and i cant get the rear to go lower. I have adjusted the rear coil to its lowest point and this is where she sits at. Did i install the coilover wrong? i thought i would be able to go lower than this. the front has no problem going lower.Is it possible to put the rear coils on the front by accident? Attachment 252922
You can get a hold of drop blocks. That will give you a good inch or so more. I would hate to adjust the spring perch, losing the preload it was spec'ed for. You can contact one of the vendors here, which can get you extreme drop struts, which all you need is to swap them over. I believe they are roughly $100 each.
CircuitMS the rear lower shock body has less play than the fronts i have this issue also is there a solution for these kits? Or are we just stuck with it and have to buy new struts down the road? BC should be aware of this cause there's a good amount of members that have this problem with these series BC coil's
Honestly its not that low, killed the wheel gap but still has plenty of ground clearance unlike the gs if you lower it this much its scrape everything. Price is slightly cheaper then BC. D2/Ksport same thing Megan/BC are also one company. Im Sure cuicutMS will be in here bashing me how bc is so much superior to megan,d2,ksport... My personal opinion is i personally installed and tested at least a Dozen of BC/D2/Ksport/Megan and to me they are very simular. I dont see a bigger body that BC claims over the Megans. They are simply different color everything else is exaclty the same. Mounts,Springs,dampning adjustment ***** and even spanner ranches are the same with a diffrent name on them.
