LS430 Most Miles?
Old 07-22-12, 09:27 PM
tcr101
tcr101's Avatar
Originally Posted by midwest2
How has it held up? Have you had to replace suspension components at all?
2001 Non-UL, No Navi, no ML.
Other than your standard 5k Oil Changes, new tires, and brake pad/rotor/fluid changes I have had to replace shocks at 140k. I believe the master brake cylinder was also replaced around 150k. Transmission flushed at 190k (toyota dealership). Valve-cover gaskets(both sides) at 190k. They looked fine, but the rubber was hard (~$45 dollars for both gaskets and 2-3 hour DIY). Also had to swap out the hook/trunk dampeners as they began to sag around 160k. Had a shop swap the water pump/timing belt at 120k. Got the components ready to have them swap it again when I hit 220k.
I believe this car will do 300-400K no problem. I do drive quite spirited every couple of weeks and the car seems to be fine. I check the radiator level, oil, power steering fluid, brake fluid levels every month or so.
Old 07-28-12, 05:12 PM
toyo
toyo's Avatar
A customer of mine has a LS400 with 398K miles. I did a huge major service on it about 6 months ago. Still runs great, quite and smooth.
Old 07-28-12, 11:47 PM
jwillis123
jwillis123's Avatar
2004 LS 66,000 miles... looking forward to going to 200k +
Old 08-13-12, 03:39 PM
tobe1424
tobe1424's Avatar
I am interested in knowing as well
Old 08-13-12, 07:58 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
At least there is at least 1 LS that beat the Toyota Prius with 351k!!!!
Old 08-14-12, 02:40 AM
sjohnson83
sjohnson83's Avatar
2001 318k miles
I use the car as a taxi/livery in nyc. Purchased in 2005 with 85k miles on it.
Oil changed with 5/30 M1 every 6 months (20k miles)
Regular fuel
Trans drained and filled, and BF changed every time i change my front brake pads or about once a year.
tb/wp done for the first time 260k.
at 310k i did struts all 4 strut mounts and lower control arm bushings.
Old 08-14-12, 02:36 PM
Caydoc
Caydoc's Avatar
2004 Premium, 27000 miles
Old 09-10-12, 07:53 AM
koesterjv
koesterjv's Avatar
2002 189,000. Noticed a small hesitation when accelerating from a stop this morning. Got onto the expressway and noticed it again cruising at 65mph. I need to get fuel, maybe some new will solve the issue. Be in touch.
Old 09-13-12, 01:54 PM
LS400TX
LS400TX's Avatar
my 01 ls430 UL has 190k
Old 09-13-12, 06:29 PM
Luke27617
Luke27617's Avatar
2004 with 44K miles. Got it 9 months ago with 36k.
Old 09-13-12, 06:31 PM
Mob4life
Mob4life's Avatar
2004 LS with 193,000 miles
Old 09-13-12, 06:35 PM
Pamperme
Pamperme's Avatar
Originally Posted by sjohnson83
2001 318k miles
Regular fuel
I'd ride in that taxi anytime. Sounds like it be one of the nicer taxi's around. Lol.
Old 09-13-12, 06:37 PM
Pamperme
Pamperme's Avatar
2004 Lexus ls 168,000.
Old 09-13-12, 10:32 PM
Michaeldc
Michaeldc's Avatar
I have a 2005 with less then 86K
Old 09-14-12, 10:15 AM
Pamperme
Pamperme's Avatar
2001 318k miles
Regular fuel
Has the alternator or the starter ever been replaced, or are they both original?
Quick Reply: LS430 Most Miles?
