LS 430 Acceleration issues
Old 06-19-12, 02:39 PM
amcb
amcb's Avatar
Default LS 430 Acceleration issues
My 2002 LS 430 recently started misbehaving. When I floor the accelerator the car hesitates 3-4 sec then starts to accelerate. Almost like it cant find the gears. and once it starts accelerating it does not really go like it used to.
Any ideas?
Old 06-19-12, 02:50 PM
Dirtyd210
Dirtyd210's Avatar
you arent using regular gas are you? poor performance can result...
Old 06-19-12, 03:07 PM
amcb
amcb's Avatar
Dirty D's Thanks, good point but this is beyond a quality of gas issue.
Old 06-19-12, 03:28 PM
AlexusAnja
AlexusAnja's Avatar
Could be throttle sensor is bad... had that issue with my RX. MAF might be bad too... hard to say.
Old 06-19-12, 06:34 PM
RWR
RWR's Avatar
My 2001 LS430 had a similar issue. The problem turned out to be an erratic MAF sensor and a dirty throttle body. Dealer replaced the MAF sensor and cleaned the throttle body and now it runs like new again. The transmission was not touched.
Old 06-19-12, 10:12 PM
ancdmd
ancdmd's Avatar
Do you have any engine knock/pinging?
Old 06-20-12, 06:52 AM
amcb
amcb's Avatar
Wouldn't this condition through a check engine light error, But this has not happened.
Did your condition turn on your check engine light?
Old 06-20-12, 06:53 AM
amcb
amcb's Avatar
Was your check engine light on with the erratic MAF?
amcb
amcb's Avatar
No knocking or pinging.
Old 06-25-12, 04:15 AM
RWR
RWR's Avatar
The check engine light was NOT on when my LS430 had this problem. Dealer did say there was a history of some MAF codes but they did not cause the check engine light to illuminate.
Old 06-26-12, 09:48 PM
jholem1
jholem1's Avatar
I had a similar problem and it turned out to be a bad fuel pump. Had it replaced and no more problems.
Old 06-27-12, 07:55 AM
parkerjs
parkerjs's Avatar
Sure sounds more like a mixture problem than a transmission problem. Are there any codes to help narrow the possibilities?
Old 04-03-13, 03:29 PM
amcb
amcb's Avatar
I had it diagnosed and it turns out the K&N filter I use was allowing too much dust/oil past and built up on MAF sensor, cleaned that, problem went away.
Old 04-03-13, 03:51 PM
HiloDB1
HiloDB1's Avatar
Good to know. Also appreciate you updating this thread with what you found and how you corrected your issue. This will definitely be a help to someone else at some point.
Old 04-03-13, 06:28 PM
Lust4Lexus
Lust4Lexus's Avatar
Throw that thing away. It's not worth the troubl imho.
Quick Reply: LS 430 Acceleration issues
