Data Systems Controller asc680 how to?
Old 05-12-12, 02:41 PM
clammbo
clammbo's Avatar
Default Data Systems Controller asc680 how to?
I looked thru the sticky notes on the asc680 but I can find instructions on how to work it? since it is in japanese.....
Old 05-12-12, 03:59 PM
ultm8mind
ultm8mind's Avatar
Lemme see what I can find....
Old 05-12-12, 04:08 PM
ultm8mind
ultm8mind's Avatar
Button descriptions
Top left button: Mode button (switches between the setting modes)
Bottom Left button: Select button (switches between the settings in each mode)
Top Right button: Up button (change values up in settings, or in height select mode it switches between height settings)
Bottom Right button: Down button (change values down in settings, or in height select mode it switches between height settings)
Initial Screen
When you first plug it in, it should give message, then it will ask you to select your car. It gives the chassis number, and underneath that it says the car name in Katakana. Yours is the Ucf30 or 31 obviously. Press SELECT to confirm
Then after pressing Select, it will ask you to select between ホアンキジュンMODE and EXTRA-DOWN MODE. Should be obvious, but EXTRA-DOWN MODE is what you want. Lets you adjust while driving and lets you get lower. Press up/down to select this, then press the select button
Lastly it will give you the height setting screen
If you had already gone past that and want to change chassis,
With the ignition off, press and hold the Mode button while you switch the ignition on. You can then select the chassis, and ホアンキジュンMODE / EXTRA-DOWN MODE.
If you did the chassis correct and just want to set extra down mode
With the ignition off, press and hold the SELECT button while you switch the ignition on. You can then select between ホアンキジュンMODE and EXTRA-DOWN MODE.
If you selected extra down mode, when you turn the engine on, you will get a message on the screen that says "WARNING!!", otherwise it will have the R-SPec logo. The warning is there to tell you that you have selected an "illegal" mode, so just ignore it.
Mode Cycle
After the warning/Rspec logo, you get the height setting screen.
From there, if you press the MODE button, you go to the TEMS setting screen. Thats the shock absorber stiffness.
Press MODE again and you go to the VALVE MONITOR screen (lets you see what the valves are doing)
Press MODE again and you are in the HEIGHT MONITOR screen (see the current height of your struts)
Press MODE again and you are in the SPEEDOMETER Mode Press MODE again to go back to the height Setting screen....
i.e.
Height Setting screen
TEMS Setting screen
VALVE monitor screen
HEIGHT monitor screen
Speedometer screen
Back to Height Setting screen
HEIGHT SETTING Mode
Display explanation
Top left - TEMS setting icon
Bottom left - Speed alarm
The 4 '=' type symbols around the centre number - height setting bar for each strut
M1 - height memory number
Display number in the centre is the height setting display
Under that in the manual it describes the Bargraphs. In EXTRA-DOWN mode you would look at the bottom left pic, which goes from L9876543210ABCDEF and FEDCBA0123456789
In the height setting mode, pressing UP/DOWN will select between NORMAL SELECT (normal mode), and M1-M5
Regarding the centre number: Thats basically the height setting of the rear struts.
This is the main screen you will be in. Press UP/DOWN to switch between memory settings...
To set a height memory...
In Height setting mode, on any given memory setting (M1~M5), press SELECT to start the edit mode.
* First setting is ALL STRUTS - Pressing up or down sets all struts at the same time
* Press SELECT again to switch to FRONT LEFT strut setting - press up/down to select a height
* Press SELECT again to switch to FRONT RIGHT strut setting - press up/down to select a height
At any point, press MODE to save the settings
Example:
Setting a height in Memory 3 to Front(5) Rear(3)
From M1 position, press up/down to select M3
Press SELECT.
Press DOWN to set all struts to 3.
Press SELECT
Press DOWN to get the front left to 5.
PRESS SELECT
Press DOWN to get the front right to 5.
PRESS MODE to save the settings
In order to do balance left/right, just set the front left and front right struts to the required values.
Note that to get into HYPER LOW DOWN mode (L on the display), when you get down to 9 on the height select screen, you need to press and hold the DOWN Button for 3 seconds
There are a bunch of warnings there but the resolution is too low to read them all
Something about under 10km/h
Something about going from hyperlow to normal mode taking more than 5 minutes
And something about not switching the ignition off while in hyperlow mode.
Also, after Hyperlow mode, in order to raise it you need to go to at least height setting 4 or above (i.e. 4,3,2,1,0,A,B,C,D,E,F). Or Normal Select Mode.
Valve monitor mode
probably doesnt need explaining
Note you can also see the valves in the main height setting screen - the pic in the centre is a little car, with the wheels on the top left right top and bottom
Heignt monitor mode
press up or down to select between having HEIGHT モニター displayed or not.
Note in the main screen you can also set it to show the current height instead of the height setting, by pressing SELECT for 2 seconds
Speedometer mode
From the main speedo display screen, press SELECT to set the alarm setting
Press up/down to set a speed, then press MODE to save the setting
From the main display screen press SELECT twice to set the warning setting
When you pass this speed, the backlight will change as a warning
Old 08-11-12, 07:05 PM
CJITTY
CJITTY's Avatar
Just want to say huge props to ultm8mind for this outstanding post
Danny786 (07-28-21)
Old 08-12-12, 03:42 AM
ippo
ippo's Avatar
Huge props indeed! Can we make this sticky? I want an ASC some day too.
Danny786 (07-28-21)
Old 11-16-13, 03:35 PM
tam4G63
tam4G63's Avatar
just installed the ASC680 again into my 06 UL; I can't get it into L mode. Followed instructions held down button still nothing. Anyone have any ideas??
Old 11-16-13, 05:52 PM
tam4G63
tam4G63's Avatar
I figured it out, the switch on the center console was on high, needs to on normal to get into L mode.
Old 03-04-15, 11:22 PM
DjMidas
DjMidas's Avatar
Default Stiffer ride?
I have the controller on my 02 LS430 ul. Is there a way to adjust the stiffness of the ride on the controller? I have 22's and I have to have a good amount of wheel well space on the back (setting 0 or A) not to rub.
Doesnt look very nice jacked up in the back.
Old 03-05-15, 07:45 PM
heathervb
heathervb's Avatar
The feature you're looking for is called TEMS on the controller. From what I understand, it is available for other cars, but not for our car.
Old 07-19-21, 03:22 AM
carbon0
carbon0's Avatar
Looking to purchase a air suspension control unit for a 2008 LS600HL
Look like the Prestigious Society is out of business where can i go to purchase one?
Thanks
Old 07-26-21, 01:54 AM
4sStylZ
4sStylZ's Avatar
Ebay ? That's where I buyed mine.
Old 11-07-21, 04:44 AM
THElouus
THElouus's Avatar
i have three controllers will trade for one harness
Old 11-07-21, 04:46 AM
THElouus
THElouus's Avatar
i have three need one?
pbxcomm
04-17-23 07:33 AM
Retroplay
11-21-15 03:14 PM
AL13NV8D3R
06-06-14 06:18 PM
wcleaners
ES - 6th Gen (2013-2018)
03-23-13 03:17 PM
spikerjack
06-15-11 01:08 PM
Quick Reply: Data Systems Controller asc680 how to?
