Trans/diff fluid change based on time?
Old 02-13-15, 03:04 AM
KingLS
KingLS's Avatar
Default Trans/diff fluid change based on time?
Hey guys, I have 28k on a 2003 ls430 that I picked up about 6 months ago. I am considering doing those fluid changes just based on the age of the vehicle. Obviously it has sat it's fair share in the last 12 yrs, do fluids age or break down?
Old 02-13-15, 06:16 AM
toddmorr
toddmorr's Avatar
they do but you could debate whether the degree of breakdown in that usage pattern is material.
If it were me, I"d replace the fluids because both are so easy and economical to do.
Old 02-13-15, 06:47 AM
XJSFan
XJSFan's Avatar
I would replace all the fluids...
Old 02-13-15, 10:04 AM
Lavrishevo
Lavrishevo's Avatar
Yes, all the fluids. Helps ensure longevity.
Old 02-13-15, 11:03 AM
Jabberwock
Jabberwock's Avatar
Agree - based on age on a 2003, I'd do the following: drain and fill on AT, drain and fill 2-3 times on PS reservoir, flush and fill on brake fluid, drain and fill on diff fluid. If its long life coolant I'd inspect to see if it looks good and nice cherry clear color and maybe wait a year or two.
Old 02-14-15, 12:02 PM
KingLS
KingLS's Avatar
Thanks for the responses, didn't even consider the brake or p/s fluid but hey, might as well...
Old 02-22-15, 09:02 PM
Wheezer
Wheezer's Avatar
The book also suggests replacing the timing belt after 108 months.
RG3toDC
10-28-18 03:07 PM
sf3r8z
ES - 5th Gen (2007-2012)
09-01-14 08:29 PM
SuperCoupe400
Performance & Maintenance
19
04-10-13 07:42 AM
tftimm
10-21-11 06:48 AM
Quick Reply: Trans/diff fluid change based on time?
