Need Help
Old 04-15-12, 06:07 AM
LV430
LV430's Avatar
Default Need Help
Hi im new to this but I wanted to know my options on how to make my wheels more flush with my fenders.
Attached Thumbnails Need Help-dsc_0053.jpg   Need Help-dsc_0050.jpg   Need Help-dsc_0052.jpg   Need Help-dsc_0049.jpg
Old 04-15-12, 06:26 AM
sojah
sojah's Avatar
a couple options of varying cost.
the 1 shot 1 kill will cost you but you could always get the fenders re-workerd or new wider ones welded on.
a cheaper route would be to do a mild pull of the rear fenders and run some extra negative camber. you could get the 5mm longer than stock oem rear arms that are pretty cheap but this will only give you like 5mm more clearance at the top.
you could get the backpads of the wheels shaved down say 5-10mm if you have enough material on the wheels backpad to safely get away with loosing this much backpad and still have enough to safely mount the wheels. also need to make sure you can clear the rear brakes if you take off some of the backpad. i believe we only need a 5mm backpad if that to clear the rear 04-06LS430 brake caliper.
i'd look into getting the backpad shaved down some, the 5mm longer than stock rear arms and then do a mild pull and you'd still be way ahead of the game $$ wise than if you just got major fender work done. prolly $200 for wheels to be machined down if that, and what like $250 for the rear arms. you can pull the rears yourself with a roller arm and a heat gun.
Old 04-15-12, 08:08 AM
SQuester
SQuester's Avatar
What are the widths and offsets of the rims?
Honestly, go LOWER and see what kind of natural camber you're really working with. Your fronts look like they'll be fine. Do the obvious if you haven't already, roll the front fenders and shave/pull the rears.
Old 04-15-12, 09:16 AM
caddyowner
Recovering Lexus Addict
caddyowner's Avatar
I would go back to some wheels closer to stock size.
Old 04-15-12, 12:35 PM
ancdmd
ancdmd's Avatar
Buy new wheels!
Old 04-15-12, 03:03 PM
LV430
LV430's Avatar
Shaving the backpads, rear arms and mild pull sounds like I route I want to go. Where would I go to shave the backpads?
19x10 +10 and 19x11 +14 my fronts have a minor roll and my rear is just shaved no pull
Old 04-15-12, 04:51 PM
SQuester
SQuester's Avatar
http://rimtuck.com/setup/view/465
This is a 20x9.5 +1mm and 20x11 +6mm setup, which on top of being an inch larger diameter, they poke 3mm more in front and 8mm more in the rear than your setup. It says he's running 2* camber in the front and 4.5* in the rear, with rolled front fenders and shaved/pulled in the rear. He's member beangrower on www.vipstylecars.com.
Old 04-15-12, 05:35 PM
SQuester
SQuester's Avatar
http://www.vipstylecars.com/forums/s...ad.php?t=24921
19x9.5 +3mm, 19x11 +3mm.
Old 04-15-12, 07:58 PM
Jabberwock
Jabberwock's Avatar
Wow - different strokes for different folks is all I can say.
Old 04-16-12, 09:10 AM
InfamousLS
InfamousLS's Avatar
Who makes these +5mm RCAs??? i need litterally 5mm of camber haha.
MR2SD
01-16-18 09:14 AM
cuongdaddy
07-03-17 10:10 AM
Gerxiong89
03-12-17 06:50 PM
96celsior
01-25-12 05:13 PM
bashigs300
01-16-12 10:49 AM
Quick Reply: Need Help
