pass time
pass time
anyone else enjoy this show. I like to try and guess the time, and I have no idea what a stock LS430 would do the 1/4 mile in .... anyone know ?
12 seconds ??
12 seconds ??
umm, try more like 14 seconds,, i think you should feel happy if you ever broke into the 13's in an LS430. i love mines but realistically its not very fast. my guess is like 13.9 on a good day with perfect conditions and fresh tires/nothing in the trunk or back seat.
I believe Lexus estimates it as 14.5 at 95ish mph. I think there's a clip on youtube of a 430 hitting the quarter in the lower 15s. Not the fastest out there by any means lol. I think it has a lot to do with gearing in 5th and 6th for economy rather than performance.
This is a repost but here is a vid of a 430 on a drag strip against an RSX type-R. The 430 does it in 15.1 at 91, I'll let you see who wins...
http://www.youtube.com/watch?v=g7iUaqUyKoQ
12s?
Id have to guess its in the high 14s to low 15s. And the fastest way to get a good 1/4 mile out of our cars is NOT by using manual shifting, but rather by just leaving it in drive as the computer knows exactly when to shift and does so quicker than the "manual" selection does.
So, to get the most speed you want the most power from the engine. The engine gives more power at higher RPMs but better mileage at lower RPMs. So the auto transmission is designed to shift early to keep the car in higher gears (lower RPMs) and save gas. But if you want the most speed, you need to manual shift later to keep the RPMs higher.
Of course if you've got it floored, the auto transmission will stay in lower gears to get you moving but you will get better control shifting manually.
for better acceleration use the power button on the dash and turn off the VSC. In power mode the tranny shifts at a slightly higher RPM level. In each gear as it shifts you want the tach to come back to 3400 rpms when the maximum torque is available.
but another thing i don't care for is the inability to completely turn off our vsc or traction control. it only turns it semi off/on by disabling it via the button. someone tole me to hold the button down to completely disable but it didn't work on my car.
