LED brake light not working?
Old 03-02-12, 09:31 AM
spin420
spin420's Avatar
Default LED brake light not working?
Hello, I just got my '01 LS430 about a week ago. It has the led tails on it (oem I believe) and when I brake the "tail lamp out" warning comes up on the dash. At first I thought it was just because this often happens when using led tails, however last night I noticed that while all the tail lights are on when turned on, when the brake pedal is depressed the inner passenger-side tail (the one that is on the trunk) does not illuminate.
This is the first time I've had these types of tails on any of my cars so I don't know how to remedy the problem.
Do I have to replace the whole tail light? Should I switch back to non-led to avoid headaches?
Thanks!
Old 03-02-12, 11:40 AM
AlexusAnja
AlexusAnja's Avatar
If it's 01 it's not OEM led as starting in 04 the ls had led taillights. You have replacement and the resistor to prevent the low draw either is defective or never installed.
Old 03-02-12, 12:34 PM
spin420
spin420's Avatar
Thanks for the advice.
What I mean is that I believe the previous owner switched the tails to the oem 04-06(?) led tails.
Old 03-02-12, 01:49 PM
AlexusAnja
AlexusAnja's Avatar
Post a pic... we'll be able to tell. That conversion was done by someone here too... but it's pretty extensive.
Old 03-02-12, 03:14 PM
Boomer01
Boomer01's Avatar
Or he could have the LED 01-03 ones.
Old 03-02-12, 07:18 PM
spin420
spin420's Avatar
Yeah, I'm not sure. I just assumed they were interchangeable since I used to have a 2GS and I believe the two different types of oem tails for those were.
Here is a pic:
Old 03-02-12, 07:45 PM
AlexusAnja
AlexusAnja's Avatar
Those are after market taillights, not conversion from 04.
Old 03-02-12, 09:56 PM
GLIDESUL
GLIDESUL's Avatar
Its probly the resistors or a bad taillight. Bad part is you have to replace whole set with those cause they don't sell em saperately. I'm on my 3rd set one was replaced under warranty.
Old 03-03-12, 04:19 AM
AlexusAnja
AlexusAnja's Avatar
Actually if the resistors in unit are bad, you can big one and link in series with the wire and of will turn off the warning too... the reason.that tjw warning goes off OS that led have very little draw, so even with it working the system thinks it's blown out. So just install a 10ohm resistor I believe it is on the bad side and you'll be good...
Old 03-03-12, 11:39 AM
VIPDrizzy
VIPDrizzy's Avatar
dont mean to thread jack but where can i find those lights???
Old 03-03-12, 05:05 PM
Boomer01
Boomer01's Avatar
I bought mine off eBay.
AmanO
09-19-16 09:47 PM
jlee403
01-10-11 06:55 PM
Surfrcali
02-27-10 12:49 PM
1GStoEnvy
09-27-09 11:46 PM
Quick Reply: LED brake light not working?
