What a difference. DIY maintenance done. More to come. - Club Lexus Forums
Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS430
Sign in using an external account
Register Forgot Password?
P
Thread Tools Search this Thread Display Modes
Old 02-22-12, 01:49 PM   #1
Slvr surfr
Garage is empty, add now
Trader Score: (0)
Slvr surfr's Avatar
Default What a difference. DIY maintenance done. More to come.
Hey all, yesterday I replaced the plugs along with oil, air and cabin filters. Also cleaned the MAF sensor too. What a difference in performance and idling I must say. Also noticed my fuel economy goin up slightly.Can't believe how easy this car is to work on yourself. You can save hundreds of dollars if you are slightly mechanically inclined. Some questions I do have tho. I was quoted $300 to do a coolant flush, change brake and steering fluids. Is that a good price and should this be handled by a mechanic or is this a job that a DIYer can handle? Anyone change these items yourselves and how easy is it? Thanks in advance.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Slvr surfr is offline   Reply With Quote
Old 02-22-12, 02:35 PM   #2
Jabberwock
Trader Score: (0)
Jabberwock's Avatar
I'd let them do the brake and coolant but I'd do the PS myself. Search for threads on PS drain and fill - its easy and can be done in 5 minutes with 4-5 repetitions and the fluid will be nice and clean.
I replaced my front brake pads yesterday, hardest part is dismount and remount of the tires. its a 1.5 hr job if you take your time and half of that is tires. Note : I did not turn rotors, no need as they were perfectly smooth.
__________________
2006 LS 430 Black Cherry w/cashmere interior. Replacement black chrome grille (no emblem), Lexus OEM power-point storage kit to replace console ashtray, Rear Sports option sway bar, Soundgate TOYPD2 Ipod adapter. Premium option package.
2007 Toyota Highlander Limited - errand-mobile
Jabberwock is offline   Reply With Quote
Old 02-22-12, 02:36 PM   #3
bigjon42
Trader Score: (0)
How many miles on your LS ? How many since last plug change ?
bigjon42 is offline   Reply With Quote
Old 02-22-12, 04:02 PM   #4
Slvr surfr
Trader Score: (0)
Slvr surfr's Avatar
Jabber thats what I was thinking.
Big john, its an 05 with 113k on the clock. I bought the car with 73k on it and I'm not sure if the plugs were changed before then.
Old 02-24-12, 04:24 AM   #5
Finerwood
Trader Score: (0)
I am new here with a 01 Ls. I have changed the brakes front and rear twice so far and it’s not that bad of a job. Just changed the rears and have not figured out how to reset the brake pads are low light at the dash?
Finerwood is offline   Reply With Quote
Old 02-24-12, 05:45 AM   #6
Jabberwock
Trader Score: (0)
Jabberwock's Avatar
The brake pad wear sensors on the LS are effective but fairly primitive - one time use only - once they have "tripped" - they cannot be reset, they have to be replaced (or they can be diy jury rigged/repaired). Each sensor is basically a wire loop encased in a bit of plastic that is clipped to edge of brake pad. As the pad material wears, the sensor plastic bit wears away and eventually the encased wire loop also wears through breaking continuity, and that is what lights up the dash low brake pad warning light. To get the light to go off you must purchase and replace the brake sensor, or as an alternative you can solder the wire loop back together and just tie off the sensor (not clip it back to the new pad) . This will turn off the warning light but it also leaves you without a brake sensor. Sensors cost between $20-80 depending on where you source them. There are only 2 of them both on passenger side brakes. I just replaced my pads at 35K miles - mail order the pads cost $50 a set OEM Toyota. For my money I'll just replace pads at 35k intervals, and never have to replace the sensor.
__________________
Old 02-24-12, 09:22 AM   #7
jimbosr1
Trader Score: (0)
jimbosr1's Avatar
do the coolant your self.open the drain and drain it and use a wet/dry vac to suck the coolant out of the overflow tank.fill and put a new radiator cap on and you are good to go.p/s fliud is easy.use your wet/dry vac and suck that out too..brake fluid you might have someone do it.
jimbosr1 is offline   Reply With Quote
Old 02-24-12, 09:35 AM   #8
sojah
2005 Lexus LS
Trader Score: (0)
sojah's Avatar
So I just ordered new pads all the way around and some new front rotors. I do not have a low pad light on my dash but am wondering if I have to purchase new sensors or are the current ones reusable?
__________________
all your lexus are belong to us
sojah is offline   Reply With Quote
Old 02-24-12, 10:25 AM   #9
Finerwood
Trader Score: (0)
Quote:
Thanks for the info, the wife will be happy that the light will be off once I change them out. If the wife is happy, life is good
Old 02-24-12, 12:06 PM   #10
Viper6
Trader Score: (0)
Quote:
Don't forget the engine block holds near a gallon of fluid... need extensions to get to the drain plugs on both cylinder banks. Since it only calls for it every 5 years, I would spend the time to drain all the fluid, but that's me. Took me longer to find the drain valves the first time than to slip a drain tube over them and get a wrench up there to loosen... next time it shouldn't take but 10-20 minutes extra time, FYI.
Viper6 is offline   Reply With Quote
Old 02-24-12, 03:43 PM   #11
Jabberwock
Trader Score: (0)
Jabberwock's Avatar
I ruined the water pump on a 1979 Grand Prix trying to do my own coolant flush cause I did not know what I was doing. It ran dry just for a minute and that was enough to fry the bearing.
__________________
Old 02-25-12, 07:44 AM   #12
Finerwood
Trader Score: (0)
Quote:
Getting ready to do mine, were are the drain plugs on the cylinder banks? Can you point me to the right area?
Any one ever do the timing belt by them selves?
Thanks
Paul
P
Tags
antifreeze, brake, brakes, dont, dry, es350, fluid, forget, is350, lexus, light, low, suck, vac, warning, wet
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Contact Us - Club Lexus Home - Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
