I Don't want to spend $3100 to replace cats
Old 02-12-12, 11:33 PM
scottgolf
scottgolf's Avatar
so did you ever give a muffler shop a try? what did they quote you? I can understand not wanting to put on after market parts, but for me I have for exhaust in the past and never had a problem. Think about places like midas or something.
Old 02-13-12, 11:58 PM
pacinitaly
pacinitaly's Avatar
yea... I'll call in the morning!
thanks
Old 02-27-12, 06:24 AM
pacinitaly
pacinitaly's Avatar
hello all
the reason for the smell is the use of ethanol. in this piece of $h!t state
no codes, lexus ht me for ($130) and said ooooooohhhhhyea need to spend $3500... to replace the 3 cats
toyota said only 2
said to wait for an issue (bogging down )
I love my toyota dealer ( the kid that helps me all the time needs a bonus I want to give him a $1000 to his church )
thanks all
dumping this car in 336hours for the lously $12k-maybe
Old 02-27-12, 07:13 AM
hoonunya
hoonunya's Avatar
Originally Posted by pacinitaly
hello all
I have some friends that have M-series Bimmers. They go to ethanol free stations.
here is a link
http://pure-gas.org/index.jsp?stateprov=FL
Can the smell clear out some over time?
Old 02-27-12, 09:49 PM
GS4_Fiend
GS4_Fiend's Avatar
If you dont have a code for cats DO NOT CHANGE THEM. You are wasting your money. The sulfer smell you are getting is because of the gas quality from the place you are getting. Try switching gas stations.
Old 02-28-12, 08:10 PM
pacinitaly
pacinitaly's Avatar
here is a link
THANKS SO MUCH!!
I've used about 15 different stations. I'm going to wait for a code or brakedown.
I wanted to trade it in for an 06 but no way I can afford it anymore
Old 02-28-12, 10:37 PM
GS4_Fiend
GS4_Fiend's Avatar
THANKS SO MUCH!!
What are your fuel trims? STFT and LTFT, post them up.
Old 02-29-12, 05:17 AM
JohnLS430
JohnLS430's Avatar
My 1992 LS400, and 2002 LS430 had/have the stank issue on hard acceleration, seems like the stank always winds up in the passenger compartment regardless of A/C settings, no codes ever set. Dealer could never duplicate the issue, yet I could duplicate upon leaving the dealer.....Go figure.
Don't bypass the cat, it will goof your system. My2c
Old 02-29-12, 07:36 AM
ancdmd
ancdmd's Avatar
Try cleaning the MAF sensor and throttle body.
Old 03-04-12, 06:33 AM
pacinitaly
pacinitaly's Avatar
I don't know what these are
WOW !!!!! I have to check this out thanks so much
I just put $86 of 93 shell, got on the freeway went 20miles - hammerdown and the funk plays on
Old 03-04-12, 10:22 AM
ancdmd
ancdmd's Avatar
I just put $86 of 93 shell, got on the freeway went 20miles - hammerdown and the funk plays on[/QUOTE]
Where in Florida are you located?
Old 03-04-12, 10:57 AM
Finerwood
Finerwood's Avatar
Originally Posted by xsbc63x
check rock auto, or aftermarket. should be much cheaper.
EASTERN CATALYTIC CONVERTERS Part # 40523, Rock Auto...
The price on Rockauto is $186.78 each. If you put on two at a time and the shop charge you $200 for labor you would be out around $600 total. If you needed to change them out a few times $ 3100 divided by $ 600 would come to 5 times that you could change them, to get to the same price that the dealer would charge. Now do you really think that you would change them out FIVE times in your life time or in the cars life time? Sounds like a no brainer to me...
I have a mechanic friend that has a small shop with a lift, and there all small shop mechanics all over. If I took the car to him with the cats in the trunk, he could, and would, change them out in an hr or two.
Do you really want to sell the car for a $ 600 repair bill? Not sure I get the issue here?
Old 03-13-12, 08:27 AM
pacinitaly
pacinitaly's Avatar
you're so right
by the way...my sub just blew again ( this time not under warranty )
Old 03-15-12, 12:09 PM
curiousB
curiousB's Avatar
Are you sure you even have a problem? In newer models the OBDII montiors the CAT efficiency with pre and post CAT O2 sensors. The ECU will log an error (P0420 or P0430) if the CAT is deemed not working.
I would never start spending $$$ without looking at the real time signals of the O2's to see what they look like. Get an OBDII interface for your laptop and do some diagnostics before you start spending money on repairs you might not need. For $100 of so you can get all you need to monitor.
Old 08-04-12, 05:22 PM
rukool
rukool's Avatar
Default Catalytic converter mechanic
I was just told I needed to replace the cats on my 2005 LS 430 right after having timing belt changed! All the typical codes came up, so I took it back to dealer to have them checked. Dealer says no rush so I am looking for an honest, qualified mechanic in the North Dallas area ( Plano, Frisco, McKinney etc.) I will get the parts from Rock Auto. Thanks!
Quick Reply: I Don't want to spend $3100 to replace cats
