Creaking noise when turning the steering wheel
Old 12-20-11, 03:36 PM
B43088
B43088's Avatar
Default Creaking noise when turning the steering wheel
Hey guys for about a week now I've been hearing a creaking sound when turning my steering wheel left and right. I cut the car off and on so the wheel would retract and protract to see if I noticed those creaking sounds, but it only happen when driving the vehicle and turning the steering wheel… just wondering if anyone have a idea what it could be or heard of this issue before if so can u plz respond
Thanks
Old 12-20-11, 06:13 PM
ThomasGS4
ThomasGS4's Avatar
Grease the U-Joint right above where the steering shaft comes through the floor.
Old 12-20-11, 10:14 PM
GLIDESUL
GLIDESUL's Avatar
Where is the sound coming from the steering wheel or suspension.
Old 12-21-11, 09:01 AM
B43088
B43088's Avatar
I'm not really good at things like that but what type of grease I need and should the u- joint be by or below the pedal
Old 12-21-11, 09:03 AM
B43088
B43088's Avatar
The sound is coming from the steering wheel, I just really hope it's nothing major because I'm not a DIY type of guy and I know the shop gonna charge
Old 12-21-11, 09:04 AM
ThomasGS4
ThomasGS4's Avatar
https://www.clublexus.com/forums/gs-...ueaking-3.html
Not an LS, but should be very similar if not the same.
Use white lithium grease, either in a spray can or a tube. The U-Joint is below the brake pedal. If you look under there, you should see it.
Old 12-21-11, 04:38 PM
jimbosr1
jimbosr1's Avatar
i just greased the u joint on my 86 mr2.i used high temp grease.works great.
L3XUSFAN
ES - 6th Gen (2013-2018)
12
01-27-19 09:50 PM
lexuschar
RX - 3rd Gen (2010-2015)
12-04-16 01:13 AM
GordoNx3o9
02-15-09 07:07 AM
dojoman
01-25-09 06:41 AM
Quick Reply: Creaking noise when turning the steering wheel
