Those of Us That Have Installed Aftermarket Subs...
Old 10-12-11, 05:55 PM
geekhou05
geekhou05's Avatar
Lightbulb Those of Us That Have Installed Aftermarket Subs...
What did you do to mount the sub in the rear deck?
I extended the wireing and connected it and it works. What I am not getting the "full effect" because the sub isnt completly mounted to the deck.
I bought the Kicker 10C88 and I have the Mark Levinson system.
Thanks
Old 10-13-11, 05:14 AM
sojah
sojah's Avatar
i had my rear sub removed completely, a custom top center-ish ported box made (port goes up through stock sub location), and installed the new sub & amp in the trunk. sounds 100 times better this way in my opinion cuz the UL trunk is very restrictive in my opinion, but you may not have this issue if not a UL. Plus i finally got the bass sound proper with a cache' sound blending modifying type device which takes in all the signals from the entire ML system and outputs whatever specific dbl range you tell it to put out. This alone caused a dramatic increase in bass quality plus the ported box and now i have a single sub that sounds as fantastic as the rest of the ML system. i think the ML should have had this as an option from the start
Old 10-13-11, 05:16 AM
64impalaSS
64impalaSS's Avatar
I used 4 #8 3/4 inch self tapping sheet metal screws. I drilled them right in with no problem and it is secure as can be.
Old 10-13-11, 06:55 AM
yuri.ber
yuri.ber's Avatar
I got the same kicker comp8 sub and mounted it in the same bracket the original was in, fit right in. While there I dynamatted the whole rear deck and behind seats. Sub's working off stock ML amp, sounds great.
Old 06-07-12, 11:11 AM
vamel
vamel's Avatar
Hey Yuri, could you tell me how did you connect the red and black wires that were soldered to the ML sub, whch one of them was positive and negative... Thanks.
Old 06-09-12, 07:49 AM
yuri.ber
yuri.ber's Avatar
I cut the wires. On the kicker sub there are markings near + and - terminals. Red wire is + (positive) and Black is - (negative).
Old 06-09-12, 12:55 PM
vamel
vamel's Avatar
Hey Yuri, thanks a lot for the info, highly appreciated...
Spasibo drug...
lexusisgs
RX - 3rd Gen (2010-2015)
12-19-17 02:18 PM
srt4evah
10-06-14 12:13 PM
anthrax144
04-15-11 06:03 PM
Stelth91
10-02-07 07:45 AM
Salil022
06-15-07 08:21 AM
Quick Reply: Those of Us That Have Installed Aftermarket Subs...
