$600 later, my mystery is solved. Might help you someday.
Hey guys:
I just wanted to close the loop on the mysterious failure of power to the windows, doors, trunk, gas flap, and outside mirrors, using the driver's side controls or the remote, on my 2001 430.
Some here suggested it was fuses. I checked and my mechanic double-checked. Nope, all fuses were fine.
One poster suggested maybe it was something called a body sensor, which I learned is actually a "body control module," and is located under the trunk fuse box. Nope. Not that either.
A Lexus expert at the site Fixya said, given my symptoms, it was probably bad wiring in the driver's door. Nope, not that. But closer.
Two days ago I took the car into Lexus of Westminster (So.Calif), where a mechanic named Mitch used electrical probes to solve the problem in a couple of hours.
It was a short caused by a faulty wiper sensor!
I have no idea where's it's located, but it was the problem. He put in a new one and everything works fine. Part was $300, labor was $300.
Along the way, I learned that my local Toyota dealer will work on Lexus cars, and the service guy said they see a lot of them. But they don't have the wiring schematic for Lexus so I didn't go that way.
I'm no expert on Lexus dealerships, having only been to one previously. But Lexus of Westminster, at least on the service side, seems first rate. Very nice folks.
I hope this helps someone Googling their problem in the future.
Aus430 (11-17-21)
Appreciate the informative and potentially very useful post - Thanks!
Got most of it fixed myself, still have some trouble with some controls and my license plate light doesn't shut off.
thanks for the information, We will keep this handy if something so happens. I still need to find my fix...
Nice find, I have the same problems! My windows go down but I can't control all 4 window from the driver side master. Each door window switch only work. Ill look into it. Thanks for the info.
Sorry, but i have to butt in...
This thread is pointless... Basically it describes problem, cost of solution, but NO solution !
It sounds like 'well he replaced SOMETHING, idk what, and "I have no idea where's it's located, but it was the problem" , and it's fixed now... yea, it cost 600usd ! that's the solution !'... What ? To have 600usd ?
Where is the solution ? Exact part name ? Part number ? ANYTHING ?
Sorry, but had to vent....
Sorry, but i have to butt in...[COLOR="Blue"]
From the OP text - "It was a short caused by a faulty wiper sensor!"
What is that ? Was the short IN the 'wiper sensor', or 'faulty' part somehow caused short elsewhere ?
It's still a mystery if you ask me
EDIT: just especially checked part catalogue, and there's no 'wiper sensor' present in Lexus LS430.... Only sensor, related to wiper system is rain sensor, and it is glued to the windshield behind the rear view mirror. I'm sure the OP would notice, if his rear view mirror been reglued etcetcetc.... So, still a mystery...
Thank you for this thread.
Just a note - this sensor isn't glued to the windscreen - you can just unclip it by hand sitting in the drivers seat.
You don't even need to replace the sensor as the wipers still work fine without the automatic function. Automatic simply becomes regular adjustable intermittent wipe.
LANewsboy
09-09-11 07:03 PM
LANewsboy
09-08-11 08:45 PM
