window tinting problem
Old 07-20-11, 11:45 PM
bfg23
bfg23's Avatar
Default window tinting problem
Hey guys. I had a mobile guy head to my place today to get the tinting done on my car. Upon pulling the first door panel off he rings me and says its gonna be difficult to do the tint as the rubber moulding around the window is all one piece, and does not just clip on and off. He said there is a strip of metal within the rubber moulding and its riveted to the door frame* (it was all bit vague to me as I was not at home looking at what he was talking about, but thats the best description I can give).
He made a few phone calls and several of his tinting buddies said these late model lexus's are a PITA to work on due to this exact problem. One of his buds said they did a 430 a while back and had to make a slice in the rubber to get it all smicko.
Long story - short. I still have no tinting done, and am unsure what step to take next, so I said I would ask on here and see if anyone has encountered this problem and knows a way around it.
Thanks gods.
Old 07-21-11, 12:58 AM
VNN326
VNN326's Avatar
i got my windows done, CLEAN AND SLICK. no cutting of the rubber at all. maybe hes just not experienced.
Old 07-21-11, 01:18 AM
dejavu157
dejavu157's Avatar
did u guys tint ur whole glass to? or only whats visible.
Old 07-21-11, 03:55 AM
bfg23
bfg23's Avatar
Only whats visible.
He has 15 years exp, and his off sider has 10 years so I think they know what they are doing. He said only other car he has seen like it in 15 years of tinting was a late model BMW M5.
I had a look in the service manual, and it seems the glass track is riveted on, so ill remove that tomorrow myself and get him to come back and do it.
Old 07-21-11, 05:50 AM
GLIDESUL
GLIDESUL's Avatar
Mines was tinted only problem I have with ul double pane glass is driver window snags rubber seal near mirror when going up sometimes, I keep rubber lubricated and no problem.
Old 07-21-11, 07:40 AM
ttran832
ttran832's Avatar
He's got years of experience under his belt, doesn't mean he has quality work. Take it to a shop that is bonded. IMO. Good luck.
Old 07-21-11, 11:40 AM
HiloDB1
HiloDB1's Avatar
My good friend is an excellent tint specialist. He had the same issue with an LS430 but he managed to get it tinted without cutting that piece. He did say it was a PITA though.
Old 07-21-11, 12:03 PM
Infamous 1
Infamous 1's Avatar
I have mine done without issue. No taking door panels or moldings off.
Old 07-21-11, 04:29 PM
bfg23
bfg23's Avatar
Were you guys there when the tinting was done?
My guy has done several of my previous cars, and many friends cars without any problems, this is the second car he has had problems with in 15years in the business. He told me he can probably pull it apart and get the job done, but I was not at home at the time and he did not feel comfortable drilling my car apart while I was not there.
Thanks for the somewhat re-assuring reply though HiloDB1.
I have rang a few shops and they all have similar problems with prestigious luxury vehicles. I am pulling apart the interior myself today anyway and he will come back around and just tint the windows.
Old 07-21-11, 04:38 PM
mewhee
mewhee's Avatar
As another suggested, you might want to take it to a professional brick and mortar tint installer (get a quote ahead of time if possible). My '02 CL took almost twice as long as others in the shop but they told me ahead of time that that's the nature of the beast.
Fwiw, my installer in Orange County had a computerized template with which to precut the tint assuring a perfect fit, which it was.
Yes, they can be a PITA to work on, especially the rear window with the inclusive high profile wiring. They had two pro installers, both w/ blow driers working in tandem in order to get it virtually perfect.
Btw, no cutting of the rubber moldings was necessary.
Good luck in whatever you decide to do.
Old 07-24-11, 04:52 PM
AlexusAnja
AlexusAnja's Avatar
Okay, are you tinting down to the rollers for a reason? I got my LS430 tinted and they went down perhaps 1/2" below the rubber door seam and it hasn't had any problems in 2 years I've had the tint. The tint place I went to went up to the window top edge and he didn't have to remove anything.
I'd say bring your LS to another shop that knows the LS430 because the person you're seeing now doesn't.
Old 07-24-11, 07:49 PM
bfg23
bfg23's Avatar
All is well. I drilled the rivets out and had another shop do the tinting. Got it done cheaper since I had already taken the door trims off which was a bonus.
Alexusanja - LS430 are like hensteeth here in Australia. You might see another one on the road once every few months if your lucky. Most shops have never seen one let alone worked on one.
Old 07-25-11, 02:58 AM
Dutchie101
Dutchie101's Avatar
Good to hear you got it sorted
Old 07-25-11, 11:13 AM
GR6RR
GR6RR's Avatar
I just had mine re-tinted this past weekend, they didnt have to remove anything... just thought I'd throw this in here...
Old 07-25-11, 01:18 PM
RA40
Super Moderator
RA40's Avatar
+1. Not necessary.
When I was tinting glass, I liked to remove the panels to run the film below some of the seals but it was just additional time lost. A guy that is good has the tools to slide the film under the trim. Cutting the rubber... The car does not need to be altered. Find another installer.
Quick Reply: window tinting problem
