A/C Refresher Kit - How the Techs Use It
Old 06-22-14, 06:11 PM
  #31
Lavrishevo
Lavrishevo's Avatar
Update. Got a chance to do the spray bottle and 70% rubbing alcohol. Works well. Just left the doors open and ran her for about 10 min while slowly sparying down 3/4 of the bottle of alcohol. You can see it all draining out the tubes as well. The air is fresh and clean now.
Old 06-23-14, 12:12 AM
  #32
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Looks like ebay has the refresher kit for Lexus/Toyota for $22.00 shipped.. cheaper than Sewell...
Old 06-23-14, 08:50 AM
  #33
Tom57
Tom57's Avatar
Originally Posted by Lavrishevo
Ok, so the consensus is to leave the compressor on now. Will do.
This "How To" says leave the compressor off.
Old 07-07-14, 04:11 PM
  #34
tmf2004
tmf2004's Avatar
Originally Posted by pizitz70
I realize its been a very long time since I started this thread but I wanted to give an update on my situation.
After more searches and additional reading on the AC Refresher Kits, I decided to try a different approach.
I came across someone who told me that some Toyota techs are using a simple solution of 70% Isopropyl Alcohol to solve the annoying AC smell problem. I did this cheap and easy procedure about a month ago and the smell has yet to return.
The Procedure:
  1. Fill a basic spray bottle with undiluted 70% Isopropyl Alcohol
  2. Start the vehicle and turn the AC on max using outside air
  3. Raise the hood and generously spray the alcohol in and around the intake grate at the bottom of the windshield near the firewall. Don't be shy. I sprayed .5 liters
For me, the results were exactly what I was looking for. The musty smell was immediately removed and remains so one month later. I did this without removing the cabin filter. I turned right around and did this on my GS300 as well. Same results!
I have no need to purchase AC Refresher kits and breathe in those added chemicals now. Thank you all who contributed to this thread.
My theory is this --- The smell is coming from pooled water down in the air intake area. Some of that water cannot escape. It sits there and eventually bacteria begins to grow producing fungus and the smell. When you hit that area with all that alcohol, its sanitizes it somewhat.
placed my order today for the kit... I will give the kit a try then try the alcohol method if this doesn't work... or should i just do the foam than the alcohol method in the vent area?
any pics of the drain tube from your GS300?
thanks
Old 07-08-14, 11:35 AM
  #35
tmf2004
tmf2004's Avatar
so got my kit today in one day from Lexus of Miami, it worked as far as i can tell... smells fresh and much better... I did have about 1/4 left or less of the small can as i couldn't get any more out... Guess i'll try the straight alcohol next in the vents... but for now it was worth the $20... thanks OP
Bob52
GX - 2nd Gen (2010-2023)
12-24-18 04:09 PM
NIAautoDesign
CL Vendor Products for RC
02-26-18 11:35 AM
Lveyolfe
01-19-18 12:52 AM
Superfast1
05-07-17 05:53 PM
hnwg824
SC- 1st Gen (1992-2000)
09-05-03 08:40 PM
Quick Reply: A/C Refresher Kit - How the Techs Use It
