Nagisa Auto front lowering block?
Old 11-22-10, 08:42 PM
waijai
waijai's Avatar
Default Nagisa Auto front lowering block?
Can someone confirm the translation?
# Approximately +2.5 degrees front camber.
# ストロークUP(ローダウン)30mm Stroke UP (Lowdown) 30mm
# フェンダー内のタイヤ位置フロント側に約10mm Tire in the front position about 10mm fender
Does this lower your car 30mm, add 2.5 degrees of camber AND fix caster issue?
Old 11-22-10, 10:00 PM
JP2SEA
JP2SEA's Avatar
That's fine.
Not sure what you mean by fixing caster issue since there is no mentioning about the "issue". But this lowering block does the same thing as the Youzealnd SS Pro does for the front tire. The tire will move towards the front by 10mm.
Old 11-22-10, 10:07 PM
HiloDB1
HiloDB1's Avatar
Seems like it adjusts caster and adds camber. I wonder how much.
Old 11-23-10, 05:32 AM
waijai
waijai's Avatar
50,400 yen according to the Nagisa Auto website
http://www.nagisa-auto.com/products/...ml#m_c_ad_ucf3
Old 11-23-10, 10:07 AM
ViPCeo
ViPCeo's Avatar
I think u already said it this look like it would be very nice to have!
Old 11-23-10, 10:53 AM
RomanTPA
RomanTPA's Avatar
when you lower the car, your fron wheels go back naturally
caster = wheels moving from front of the car back or the other way around
^^^ Lots of negative caster
hope that helps
Old 11-24-10, 02:17 AM
0x21
0x21's Avatar
there has been a used set on yahoo auction thats a little cheaper
http://page21.auctions.yahoo.co.jp/jp/auction/j92378582
not sure if it's worth it
Old 11-24-10, 06:05 AM
AlexusAnja
AlexusAnja's Avatar
it translates to "Little Orphan Annie says drink your Ovaltine"
If you use Google translate, it says:
Strokeup (lowdown)
and
Location above the tire in front position
for the two Japanese lines. Still though, not sure what these two parts are suppose to do.
Old 11-24-10, 02:48 PM
fergo308
fergo308's Avatar
That translation is pretty good.
the kit will drop the front by 30mm,add 2.5deg of camber,move the castor setting forward by 10mm (roughly a degree more positive),and maintain your normal range of suspension travel in the struts.
Win all 'round!
Justin...
NAZTY97
RC - 1st Gen (2015-present)
10-31-18 03:55 PM
Polo708
Suspension
10-11-17 08:03 PM
98GS400GUY
Suspension and Brakes
03-24-10 10:05 PM
robz_11
10-27-08 08:20 PM
persian451
Wheels, Tires & Brakes Forum
09-11-03 01:48 PM
Quick Reply: Nagisa Auto front lowering block?
