Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- How to Align Your Tires
Step by step instructions for do-it-yourself repairs
Do you have to get wheel alignment after putting new tires on???
Agree as long as tires show even wear no need for alignment.
But if you do have uneven tire wear, given the cost difference between 2 wheel and 4 wheel alignment usually isn't that much - I'd just get it 4 wheel aligned.
Outer edge wear can also be camber related.
If you're just going to do the front wheels, u should do all 4. Alignments only cost 50-60 dollars are firestone. I actually got the lifetime for 150 a few years back and go 3 or 4 times a year. If you're going to keep your car for a while, its definitely worth it.
Yup, Once a year depending on miles driven. Uneven wear if you do not catch it causes noise, vibration and irrepairable damage for the life of the tires. A good alignment at a good frame shop makes a world of difference. Check pressure at least once a month.
If you get an alignment (which it sounds like you need) - get a good 4 wheel alignment.
^ damn...
Yea, Alignments should be done every 6 months or a certain set mileage interval which I cannot remember right now.
Since its a new car, I would make sure its aligned properly.
