Boring (stability control)
Old 12-10-13, 09:36 PM
  #46
Lavrishevo
Lavrishevo's Avatar
That's why i said throttle control is something totally different...
Old 12-11-13, 08:30 AM
  #47
seve7
seve7's Avatar
im in the same boat here, its not that i want to drive it sideways but in snow it would be a lot easier to drive this car, the vsc kills all momentum, the tires will spin with the trac off, but if there is any yaw it still starts braking and shutting down the throttle to keep the car straight.
Old 12-11-13, 08:51 AM
  #48
Lavrishevo
Lavrishevo's Avatar
Since everything is drive by wire, you can't really do anything about that without reprogramming the ecu.
Old 12-27-18, 02:38 PM
  #49
svlexus
svlexus's Avatar
Just hook up a bosch obd tool. Reset the abs codes and it will do a malfunction where your vsc turns off.
Old 12-30-18, 11:41 AM
  #50
2KHarrier
2KHarrier's Avatar
Old 12-30-18, 11:51 AM
  #51
05ls430518
05ls430518's Avatar
Originally Posted by 2KHarrier
Lmfao also just unplug an abs sensor problem solved
Old 03-04-19, 03:11 PM
  #52
wpatriot80
wpatriot80's Avatar
It is possible to delete VSC if you install an on/off switch and it is super easy.
I think I haven't seen english instructions anywhere but here's a how to in japanese https://minkara.carview.co.jp/smart/userid/576790/car/2152996/4711786/note.aspx
pmarr
15
07-14-16 11:11 AM
DJWLDW
12-13-15 01:04 PM
Do.Man
27
07-05-09 07:21 PM
raffylong
12-01-08 01:20 PM
irieblue
02-13-08 03:04 PM
Quick Reply: Boring (stability control)
