Driving my LS in manual mode....
Old 07-26-10, 08:22 PM
kg19989
kg19989's Avatar
Default Driving my LS in manual mode....
I have tinkered with the manual shift in some cars in the past but was never really impressed. After owning my beloved LS for about six months I decided to give it a whirl. All I can say is WOW! Is it me or does the LS get torquey when you keep use the manual shift? Yet another reason to fall in love all over again!
Old 07-26-10, 08:36 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
that can't be good for your transmission if you're shifting gears when driving.
Old 07-26-10, 08:40 PM
kg19989
kg19989's Avatar
Not sure what you mean by that.... the transmission has a manual mode presumably so you can shift gears yourself...
Old 07-26-10, 09:36 PM
GLIDESUL
GLIDESUL's Avatar
Another reason I need upgrade all I have is power mode for longer rpms on my 02.
Old 07-26-10, 10:31 PM
ejthomp
ejthomp's Avatar
LOL... ya can't be good.... I mean....you shift gears while you are driving?
I thought the transmission only had three gears... Park, Reverse and Drive.
Old 07-26-10, 11:44 PM
Hawaii5oh
Hawaii5oh's Avatar
what he means is the shiftronic transmission...it allows u to shift through all gears while driving...seen in most newer cars....
Old 07-27-10, 05:17 AM
caddyowner
Recovering Lexus Addict
caddyowner's Avatar
With 6 forward gears and plenty of V8 torque, I find the LS430 shiftronic transmission to be merely a boy-racer novelty. However, in my H4 Subaru with a whopping 169 lb. ft. of torque and only 4 forward speeds, the shiftronic transmission is quite handy at keeping the engine spinning in the torque band.
Old 07-27-10, 07:37 AM
TJW98LS
TJW98LS's Avatar
At first I thought he meant shifting the original standard gear shifter... and that's probably not a bad thing, but I don't see why anyone would need to use it, other than engine braking.
The wouldn't mind the shiftronic in my LS to be honest.
Old 07-27-10, 06:47 PM
chris81964
chris81964's Avatar
I have used it and I was surprised that it would let the engine redline. In my mercedes the transmission will shift to the next gear rather then reach redline. This works like a true manual. You have to shift. Impressive power in manual mode.
Old 07-27-10, 08:57 PM
kg19989
kg19989's Avatar
Sorry to disappoint you Caddy... Although I usually drive like I am 65 I still like to get on her occasionally and the shifttonic makes it a bit more fun.
Old 07-28-10, 09:17 AM
Dailow
Dailow's Avatar
My Acura CL was tiptronic too, but it would automatically downshift and wouldn't allow you to upshift unless you were going faster than a certain speed at your current gear.
That's why I like the LS430 implementation - it actually does act like a true manual transmission and allows you to up/down shift as you'd like (RPM range permitting). It's certainly nice to know that I can shift down to 1st gear whenever I want, because the car can surprisingly pull off the line.
Old 07-28-10, 09:43 AM
Lust4Lexus
Lust4Lexus's Avatar
For me, the computer, when in power mode, usually selects a better gear/is smarter than me. I barely use it.
Old 07-29-10, 06:56 AM
CG lover
CG lover's Avatar
use mine for those downhills when it does not shift to a lower gear automatically,, occasionally use it for stop lights to assist slowing down,, have never used it for taking off and reaching those higher RPMs,, for those I just floor it and let the auto work on its own,,
Old 05-17-13, 05:51 AM
MJ96bulls
MJ96bulls's Avatar
New Lexus owner here. I was driving my 04 LS430. Stayed in 1st too long(tiptronic) and passed the redline into 7000 rpms before shifting into 2nd. Slight burning smell coming from the engine when I parked. Just paranoid because I love this car so much? Or could this cause some damage. 128k
Old 05-17-13, 07:06 AM
Lynzoid
Lynzoid's Avatar
sure it can. it's not a rice rocket....
Quick Reply: Driving my LS in manual mode....
