Steering wheel cover removal
Old 06-23-10, 10:09 AM
Vpanin
Vpanin's Avatar
Default Steering wheel cover removal
What is the next step after removing the 3 screws from the cover? The upper and lower part still stick together after the screws are removed. Does anyone know how to undo the upper and lower part without breaking it??? : )
Old 06-29-10, 01:45 PM
DDLexus
DDLexus's Avatar
help is on the way Vpanin... letme dig up some documentation.
Old 06-29-10, 01:49 PM
DDLexus
DDLexus's Avatar
Cool Tsib st001-04
This TSB is a good one to use as a guide for getting to the "guts" of the steering column. I know it says 2001-2004, but my 2005 has the same setup... i also expect that the 2006 are identical.
Good luck!
kos (08-01-19)
Old 06-30-10, 12:28 AM
dclk
dclk's Avatar
double d, you the man!
Old 06-30-10, 10:11 AM
Vpanin
Vpanin's Avatar
Thank you DDlexus! I took the 3 screws off the cover....I can feel it being loose ....now im guessing i have to pop it open somehow. I just dont know how to undo the clips that are still holding the 2 steering column cover pieces. I'm too scared to break the clips inside.......
Old 06-30-10, 11:56 AM
DDLexus
DDLexus's Avatar
wiggle it around a little. They should just pop apart in the center of both sides. I shook mine lightly and it fell apart. I wish i took a pick for you to see the clip location and girth. It shouldn't break. From what i recall, it was not a delicate snap/fitting.
Old 06-30-10, 12:23 PM
Vpanin
Vpanin's Avatar
thanks ill concentrate on the center of the covers in my next attempt
Old 05-31-15, 08:50 AM
SatComm302
SatComm302's Avatar
I know this is an old thread, but I didn't want to start another one on the same topic.
Do you have to disconnect the battery cables to prevent accidental airbag deployment before removing the steering column cover? I need to lubricate my steering column.
Thanks ahead of time
Old 05-31-15, 09:05 AM
Tom57
Tom57's Avatar
Absolutely disconnect battery to avoid accidental airbag deployment and possible injury to yourself.
Old 05-31-15, 11:09 PM
KING
KING's Avatar
Definitely +1 on unhooking the negative cable.
IT is a cautionary step to take just to be safe, and it would take you literally a minute or two to unhook the negative.
Man, even when it's unhooked I'm scared for my life that it will explode in my face.
Old 06-01-15, 08:48 AM
LiCelsior
Retired
LiCelsior's Avatar
yes remove the negative cable from the battery and then step on the brakes. this will drain out any power left in the system.
Old 06-05-15, 04:33 AM
SatComm302
SatComm302's Avatar
Thanks, everyone. Y'all are right. It just takes a minute and the peace of mind is well worth it.
Hopefully, I can tackle the steering column lubrication this weekend.
Hklexus
02-03-18 07:12 AM
shaft1
09-07-12 01:52 PM
snook
SC- 1st Gen (1992-2000)
10-10-09 05:48 AM
mcyc
07-10-06 08:28 PM
Quick Reply: Steering wheel cover removal
