DRL's replaced with LED's
Old 06-15-10, 01:29 PM
PHML
Master Thread Closer!!
PHML's Avatar
im looking for the drl module for h1 bulb type...
Old 06-15-10, 02:37 PM
Gil Smash
Gil Smash's Avatar
Yea I figured it was something along those lines, whatever though, I've compared mine (01) versus my moms (04) and its not a big of enough difference for me to care, at least when they are aimed in their stock position.
Old 06-15-10, 05:48 PM
Tee
Tee's Avatar
04-06 stock height is too low, one only needs to raise them up a bit (not a lot) and they are amazing! I understand, it's about prespetive long as you are happy then that is all that matters.
Here are some pics I took after I put in brand new HID bulbs in my 430.
For you guys that want to know how to raise the 04-06 low beams.
1st- You will need a ratchet & a 10mm socket
2nd- Park on a flat surface in front of wall with headlights on.
3rd- Behind each low beam headlight there are holes, stick the ratchet socket into the hole and turn to adjust the desired height. This will also adjust both low and high beams at the same time, that's it you are done.
Old 06-17-10, 06:07 AM
Gil Smash
Gil Smash's Avatar
Thts definitely a smoother output, maybe ill take some pics of mine to compare.
ekim
09-21-18 12:49 PM
2k11sfrx
07-30-12 08:06 PM
irokdastar
10-05-11 10:38 AM
vdeleon
02-19-11 02:31 AM
Rash
07-08-10 10:37 PM
Quick Reply: DRL's replaced with LED's
