Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS430
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 04-22-10, 01:52 PM   #31
StanVanDam
2002 Lexus LS
Trader Score: (0)
This is for 2004-2006:
Performed Repair // Fill Amount
Radiator removal // 0.7 liters (0.74 US qts, 0.61 Imp. qts)
Transmission hose and pipe removal // 0.6 liters (0.63 US qts, 0.53 Imp. qts)
Output shaft oil seal replacement // 0.4 liters (0.42 US qts, 0.35 Imp. qts)
Transmission pan and drain plug removal // 1.3 liters (1.37 US qts, 1.14 Imp. qts)
Transmission valve body removal // 3.9 liters (4.12 US qts, 3.43 Imp. qts)
Torque converter replacement // 5.3 liters (5.60 US qts, 4.66 Imp. qts)
Entire transmission assembly // 7.2 liters (7.61 US qts, 6.34 Imp. qts)
HINT: If you cannot add the listed amount of fluid, do the following:
(1) Install the refill plug.
(2) Allow the engine to idle with air conditioning OFF.
(3) Move the shift lever through entire gear range to circulate fluid.
(4) Wait for 30 seconds with the engine idling.
(5) Stop the engine.
(6) Remove the refill plug and add fluid.
(7) Reinstall the refill plug.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
2002 LS430 UL / 112k kms / Blue Onyx Pearl / Ecru Bird's-Eye Maple / Ecru Premium Leather / FormulaOne Pinnacle 15 tint /
VAISTech SL2Vi / iPod Touch 3G / Toyota Lexus Navigation DVD Gen 2-3 v10.1 86271-33049
90915-20004 oil filters / FIGS Engineering trunk struts / Interstate MTP-24F battery
225/55/17 Michelin X-Ice Xi2 + Macpek AZZ755CG rims
225/55/17 Michelin Primacy MXV4 + OEM chrome rims
Zaino Car Care Products
StanVanDam is offline   Reply With Quote
Old 04-22-10, 02:05 PM   #32
tsslaporte
Garage is empty, add now
Trader Score: (0)
Damn that's like 20 quarts for the whole thing?
__________________
05' G35 Sedan/10' RX350/05' LS430
tsslaporte is offline   Reply With Quote
Old 04-22-10, 02:08 PM   #33
StanVanDam
2002 Lexus LS
Trader Score: (0)
No, those are the amounts you fill in depending on the repair that you did.
For example, if you did a complete transmission rebuild, you would fill in 7.2L. If you replaced the torque converter, fill in only 5.3L.
__________________
Old 04-22-10, 02:11 PM   #34
tsslaporte
Trader Score: (0)
But if you wanted to flush the Transmission you would need 20.49 quarts to change out all the old fluid no?
__________________
Old 04-22-10, 02:28 PM   #35
StanVanDam
2002 Lexus LS
Trader Score: (0)
Dry fill: 10.9L
Drain and refill: 3.0L
Nothing in there about a flush, except "ATF-WS does NOT require any flushing or changing during the life of the vehicle."
It also says "Fill the transmission through the refill hole until fluid begins to trickle out of the overflow tube. Reinstall the overflow plug."
__________________
Old 04-22-10, 03:49 PM   #36
tsslaporte
Trader Score: (0)
Dry fill: 10.9L
I know what it says, but it should be changed. It would need to get plugged into a machine through the return line. So 10.9 L which is 11.5 Quarts
Thanks
__________________
Old 04-22-10, 06:53 PM   #37
randal
Trader Score: (0)
Quote:
Originally Posted by LS430inDE. View Post
You must TOW with your Lexus or powershift the tranny (lol)...right? If not, I think every 25k is pretty darn excessive!
They are not completely draining the tranny each time. Just 2 quarts at each "change". Not excessive.
randal is offline   Reply With Quote
Old 04-24-10, 10:31 AM   #38
tsslaporte
Trader Score: (0)
I just went to the dealer, they did not want to touch the tranny, They did not want to drain or flush it. The LS430 is at 73k
__________________
Old 04-24-10, 10:52 AM   #39
AlexusAnja
2010 Acura MDX
My Garage
Trader Score: (0)
AlexusAnja's Avatar
Default Reliablility
Quote:
Toyota either has full confidence in their WS transmission, or they really want us (or next owner) to replace them later. I think that if the dealer insists on not replacing something when the customer requests it, then they back up their "not wanting to" with some written statement stating that if that component breaks, they will replace at no cost.
__________________
'10 MDX blk/blk
'04 LS430 CL blk/blk (I'm on cloud 9)
'99 RX green/beige - (still smashing, but it's the beater)
N:Quebec E:Boston W:Chicago S: Orlando
AlexusAnja is offline   Reply With Quote
Old 04-24-10, 10:58 AM   #40
tsslaporte
Trader Score: (0)
Quote:
A dealer on the other coast of Florida will do it. So we might go there, I got to call around some other dealers near me see what they want to do.
The Head Service guy, was Strongly recommending we not touch it, that the World Standard Fluid is good until 100k, He said to change it at 100k, if we change it before it can make the tranny slip.
I was laughing, since they just want warranty to run out.
__________________
Old 03-04-12, 08:36 AM   #41
chris81964
2005 Lexus LS
Trader Score: (0)
My service guy said that he does not reccomend I change the fluids. I told him to do it and he said that he would not be responsible of the transmission failed after the change. Does the screen need to be changed?
chris81964 is offline   Reply With Quote
Old 03-04-12, 04:48 PM   #42
AlexusAnja
2010 Acura MDX
My Garage
Trader Score: (0)
AlexusAnja's Avatar
Quote:
Isn't that just such hogwash .... if you don't change it and the granny goes, it'll be 'oh well... guess it just went bad' but if you do change it and it somehow goes bad, then it's. 'See you should not have changed it...' guess Lexus was smart to not give an interval figuring nothing was going to happen within warranty period anyway....
Old 03-05-12, 04:57 PM   #43
warminwisc
Trader Score: (0)
The Lexus dealer in my area said to change all the fluids just makes sense.
The Yota master tech,I trust him he does the frame changes on the Tacoma under rust warrantees, just today said yes states no changes for lifetime but it can't hurt and he would change it if it was his car. he did not like power flushes. Mine was changed at 55 k now has 160k all hwy miles.
I have a good dealer not a stealer. I bring my own oil, cost of a filter and 11 bucks for labor and a car wash to boot. Wifes Camry 5.11 bucks a quart for synthetic, filter 4.55, 11 bucks labor and a wash.
warminwisc is offline   Reply With Quote
Old 03-05-12, 05:53 PM   #44
BNR34
Trader Score: (1)
This is why I never visit the dealer unless they are giving me free stuff under warranty. Oh I go there for the free soda once in a while too.
They give you nothing but absolute BS
BNR34 is offline   Reply With Quote
Old 03-11-12, 03:17 PM   #45
Randy B
Trader Score: (0)
Default Been on the fence with this issue.
Finally broke down yesterday and bought 14 quarts of WS ATF @ the Toyota dealer. After watching the flush on the machine, I was very glad I did it.
I know fluid gets dirty and eventually breaks down over time. I did not expect the fluid to be almost as black as the container for the new quarts. Could not even see the white wheel on the machine as the fluid passed. Took 12 quarts to totally flush, and since I had the extra two, we just kept it on. Probably a waste, however since it is a sealed system, I do not plan on needing two quarts in my garage. Even if it was a waste, I feel better, and that is not a waste.
BTW, 73K miles on the ride as of today.
Randy B
__________________
2006 LS430 Blue Onyx Pearl and Cashmere leather interior, Modern Luxury package with Sirius Satellite radio, Smart Access, and Sport Package with chrome 18's.
Randy B is offline   Reply With Quote
Tags
2005, 430, change, changing, fluid, gx470, lexus, ls, ls430, manual, oi, oil, owners, sealed, transmission
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
