Help Wheel Bearing Hub Assembly
Old 03-08-10, 06:28 AM
GLIDESUL
GLIDESUL's Avatar
Default Help Wheel Bearing Hub Assembly
I just wanna know if anyone can tell how difficult it is to change. Mines bad in the rear left or right. Im about to jack her up outside and give it the wiggle test. Then maybe the dealer for an second opinion. But from what i researched its the wheel bearings. That whirl whirl sound with when moving. The only time it stops is when i turning to the right. It seams like it all started shortly after i changed my stock 17" to stock 18"s. So after hearing the noise i switched back to the 17s with michelins and same noise. Back to my question has anyone have advice on replacing (wbha). its a 2002 UL 123,000 .
Old 03-08-10, 07:06 AM
vcheng
vcheng's Avatar
The rear bearings are inside a complete press-in hub assembly. You will need a shop press to remove and install. Otherwise it is failry simple to do.
Old 03-08-10, 07:18 AM
ESBob72
ESBob72's Avatar
Yeah, the whole hub assembly is the way to go. About $130 each.
Colin1JZ
IS - 1st Gen (2001-2005)
11-05-18 09:07 AM
ohiois350
09-18-18 02:10 PM
Engel
03-20-18 11:29 PM
faithmkss
10-19-13 01:35 AM
kevin.tran
Suspension and Brakes
01-11-09 09:39 PM
Quick Reply: Help Wheel Bearing Hub Assembly
