Is the sport suspension package lower?
Recovering Lexus Addict
I haven't looked at two cars side-by-side, one with sports suspension and one without. However, I think the cars with 18" wheels appear to be a bit lower because of the shorter sidewalls.
If the suspension is in fact lower, it's not a real drop. It's probably within a fraction of an inch. This is common with many OEM sport suspensions as to not loose too much suspension travel. They usually simply change the rates of the shocks/springs or go to a progressive spring.
I don't know the factual answer to this question but I agree that the sport models to appear to be lower than their non-sport brethren. In fact, my '02 definitely appears to sit lower when I have it alongside my '05 in the garage and I believe that is because of the 17's on the '02 while the '05 has 18's even with a lower side wall as caddyowner points out.
In any event, I do like the look.
Distance from floor to top of wheel opening even with each axle, measured in my garage which is slanted a bit nose down under the car:
LF, RF, and RR: 27.75"
LR: 27.5"
My car is a CL with 18" chrome wheels.
LR: 27.5"
3UZ-FEEEE
I strongly suggest changing the shocks while you are at it. The stock shocks will not be able to handle the extra load and fail prematurely. Then your suspension will fail to keep the wheels on the road causing all kinds of headaches from tire cupping to uncomfortable (and not the sporty type either) ride.
3UZ-FEEEE
Also, make sure you CUT a couple of layers of the bumper stops on. They are rubber pieces stacked together that stop the shock from bottoming out (you will see it once you take the shockmount apart), and if left at the same size, it will heavily restrict the shock travel (the car will think the shock is bottoming out, when its not.) Take away as much as 2/3ths of the rubber out.
Strongly suggest you go with Bilsteins. Aside from their quality for necessity for lowered applications, they will do the job of keeping the wheels planted to the ground as they are supposed too. They will ride a bit harsher, but are more able to handle the car (keep the wheels from bouncing) vs. OEM which were made for longer springs.
My LS430 already has the sport suspension , How much more harsh do you think the ride will be with the Df210 springs and the Bilstein shocks ?
combfilter
10-26-06 07:03 AM
Gernby
08-28-06 11:18 PM
asleep
08-24-04 01:00 PM
