LS 430....Experiences with Tanabe NF 210 and DF 210 springs
Old 01-23-10, 01:10 AM
Aimhigher3
Aimhigher3's Avatar
Default LS 430....Experiences with Tanabe NF 210 and DF 210 springs
I'm still trying to decide on ways to lower my LS.....
I'm looking at the specs for the Tanabe DF and NF springs and they they look practically the same?? The REAR of the DF springs is ONLY 0.2 more and the front is the same? I would assume that the DF model would be lower for the front and rear?
So...my question is that if the specs is basicly the same....why wouldn't I get the NF model since they claim that they ride close to stock??
If the DF springs were like 0.5 -1.0 lower than the NF model then I can justify getting them since I may have to give up a lil bit of ride comfort?
I've seen some of the members riding on the NF springs and I wanted something just a little bit lower so I looked into the DF springs but they were the same height in the front.
Any experiences with DF or NF springs ??
I was leaning on coil overs at first but after doing some research I decided to look back into springs since I dont really want to slam my car, deal with squeaks (i read that a lot of people have these issues), and having to replace the coil overs cartridges after ONLY 30,000 miles.
Here are the spec from the Tanabe website
Tanabe - DF210 (Dress Form) Spring Kit, 1.0 Inch Drop for both (FR) & (RR),
Tanabe - NF210 (Normal Feeling) Spring Kit, 1.0 Inch Drop (FR) & 0.8 Inch Drop (RR)
Or anybody can give me another suggestion on another brand of QUALITY lowering springs that is lower than the Tanabe but yet has a good comfortable ride?
Old 01-24-10, 06:42 AM
El Toro
El Toro's Avatar
I have the NF 210's and feel that they are perfect. Check my comments and pics from the thread below.
https://www.clublexus.com/forums/ls4...oil-overs.html
Old 01-24-10, 06:11 PM
SH430
SH430's Avatar
Default NF210 Springs
I converted my '01 LS430 UL from air suspension to the NF210 springs with KYB shocks. The car is a little lower than I thought it would be, but it looks great. The ride quality of this setup is very good. You will need to replace the rear camber struts. Lexus offers 3 lengths. I used the shortest ones, and the rear camber came back in specs.
Old 02-09-10, 10:33 AM
BNR34
BNR34's Avatar
I converted my 05' LS430 UL from air suspension to the NF210 springs with OEM Euro Sport shocks, it is exactly what I am looking for. Sounds like you have the same preference as well. I didn't want coilovers for the exact reasons you stated, and most coilover's company don't sell each shock individually, you have to buy the entire suspension kit or have them rebuild every 30k~50k miles, it is a pain.
I picked the NF over the DF because like you said, the DF is only 0.2" lower on the rear, and mind you since the UL is heavier on the back, it brings down the NF just enough for the perfect rake look. I also don't want the DF's higher spring rate in fear of ruining the ride. The ride is perfect for me now, it rides pretty much the same as a stock sport suspension car, it is actually a hair less harsh because the stock sport suspension have firmer A-arm bushings that transmit more harshness from the road.
Initially when the springs was first installed, the car was sitting higher then I want, but after a few months, the springs settled down quite a bit more and the height is perfect now. It is slightly lower then most stock AMGs, which is exactly what I want
See pics of my car here:
https://www.clublexus.com/forums/4973759-post1.html
Old 02-09-10, 11:11 AM
CW2004LS43
CW2004LS43's Avatar
I am interested in the NF's also, but want to keep my stock shocks since I only have 30k on my car. I could not find a thread discussing the installation of the springs. Is it a straight forward job?
Thanks for the input.
Old 02-09-10, 11:33 AM
BNR34
BNR34's Avatar
There is no discussion thread because it is a very simple direct swap straight forward job, there is nothing to discuss about
Old 02-09-10, 12:58 PM
CW2004LS43
CW2004LS43's Avatar
Thanks for the info!
Old 02-09-10, 06:14 PM
LS430black
LS430black's Avatar
@BNR34: I have a small question,I'm still wondering why you needed to convert from air suspension to springs? Are you worried about its maintenance? And are the springs smoother than the previous one or a bit harder?
Old 02-09-10, 09:26 PM
BNR34
BNR34's Avatar
You are welcome.
Old 02-09-10, 09:34 PM
BNR34
BNR34's Avatar
There are only 2 reasons to have the air suspension:
1, Height adjustability, mainly for people who want to lower their car to the ground for that unique look.
2, For that flowing on air feel.
I don't need either of those features.
There are many negatives to the air suspension:
1, The strut is $1000+ each that usually last about 50k~60k miles.
2, The car is constantly changing height at each corner individually, and the height sensor/computer is too slow, too dumb......making the car sit crooked every time you look at it. It is very annoying.
3, The ride is too soft for my taste, even in sport mode.
I appreciate the firmer ride of the steel spring and the constant static ride height much more, not to mention the longer lasting conventional struts that are $150 each.
The Tanabe lowering springs ride about the same as the stock OEM sport suspension, which is still a very smooth ride. It is harder then the air springs of course.
Old 02-09-10, 09:37 PM
LS430black
LS430black's Avatar
I got it. Thanks a lot
Old 02-09-10, 09:46 PM
Aimhigher3
Aimhigher3's Avatar
Thanks everyone! I installed the Tanabe NF springs on my car a few days ago...The ride is pretty close to stock to me.... I only wished that it was like a half inch lower or so but hopefully when it settles it be perfect!
Old 02-09-10, 09:47 PM
BNR34
BNR34's Avatar
No problem.
The air suspension was cool initally when I first got the car since it is a novelty, but after a while I realized I don't want it and got sick of all the hassles, then the 2 rear struts failed, so I ripped them out. I love the car much more now.
Old 02-09-10, 09:50 PM
BNR34
BNR34's Avatar
Originally Posted by Aimhigher3
Thanks everyone! I installed the Tanabe NF springs on my car a few days ago...The ride is pretty close to stock to me.... I only wished that it was like a half in lower or so but hopefully when it settles it be perfect!
It will come down another 1/2 inch or so when the springs settle, don't worry. I hated it in the beginning too because it wasn't low enough, but it is perfect now. Be patient, it takes 2~3 months for it to come down, but it will.
Old 02-10-10, 12:25 AM
TJW98LS
TJW98LS's Avatar
What struts did you go with? I hit my 174K on my beast... If I lower, it wont be on these struts.
Quick Reply: LS 430....Experiences with Tanabe NF 210 and DF 210 springs
