A few issues with my 06 LS
Absolutely the best car I have ever owned. 44K on my 06 burgundy and tan 430 with nav. - No warranty issues so far!
Here are the only things i need help with.
The windshield has tiny specks on it. They don't clean off with cleanser. I haven't waxed it with the Porter Cable as I do the body because I am cautious about doing any damage. Should I use the buffer?
Then, the windshield blades are a puzzle. The wipers don't flex all the way up as most wipers do for easy changing. Does everyone just work with them only slightly flexed to change the blades?
Thanks in advance
Thanks in advance
I have the specks on my windshield as well which I believe are tiny chips in the glass. I had it with an orbital but it didn't make any difference. I don't think theres much that can be done about it.
most likely tiny specks/pits generated from sand and other small debris blown from other traffic into the air and your windshield hits them at highway speed,, very common for cars that are not all slow speed in-town miles,, if you have or can borrow a 10X jeweler loupe eyepiece you can see the small indents or pits,,
when you drive into the sun at a given angle you will notice them more,, don't know any cure except a new glass,,
as for the blades, sounds like someone has installed improper blades,, my 05 has gone through several sets and never have had one that did not contour to the window shape while operating,,
Derry
Derry
CG lover
I'm sorry, but you misunderstood about the wipers. I was referring to the fact that the entire arm doesn't flex away from the windshield and stay that way- like they do on just about every other car I have seen - just so you can wash the windshield or change the blades. I don't think my 06 LS is the only one that behaves that way! - It's not a big deal, just an inconvenience.
wipers - nothing you can do about that. Poor design I guess. I noticed it when I went to change my wipers. Made it slightly more interesting to do.
window - could be tiny chips or could be something like sap from a tree. Try taking a straight edge razor to it (be cautious as the corners will scratch the glass, use a little water with some soap in it as a lube). I'll have to try that jewlers loop thing. The day I picked my car up from the dealership the windshield was remarkably clean. Looked brand new, like the glass wasn't there. Even went back and asked their detailer what they use expecting to hear about some unique commercial grade glass cleaner (water down windex and newspapers). Let us know any results you get
Nothing much you can do with wiper except to turn them on, and turn the car off just as they're in full up position. This way, it gives you maximum clearance, but then you have to stretch to reach the blades. Just bad design, but probably contributes to the good aerodynamics of the vehicle. I've only needed to change them once and I found them okay, so I can live with it.
Thanks all for their replies. Frankly, concerning the windshield, I expected more "me, too"s and "here's what I did" replies. They seem to be chips. Looking through them sort of effects the "quality of the drive" experience, but everything else is so perfect, I can "see past it.(sorry)
I would assume that the windshields were the same throughout their production or at least for a large chunk of it. Maybe they lightened it up for the last year of the 430. I'll try the Porter-Cable on it.
Thanks again
Thanks again
The wiper blade recessed a little under the hood so you do'nt see much of it on normal driving. To change the blade, turn the ign. on and turn the wiper on, then turn off the ign. so the wiper arms are in the middle if the windshield to change the blade. This wasn't a bad design, it was disign that way. LS 400 was the same when you change blade.
I use Stoners in the aerosol can. Best stuff I've ever found for windows. Newspapers optional.
the wipers DO suck..and badly
How freakin' easy does something have to be you ask? It should be as freakin' easy as the LS's brake pad replacement. How's that!? C'mon..they are WIPERS!
I thought only only AMERICAN car wipers (pre 2007...lol) didn't fold away from the glass. Not a 3 year old LEXUS---BUILT IN JAPAN!!
I started a thread on how bad, wait...scratch that...how HORRIBLY designed they are. Not only replacement of the blade or insert, but the drivers side is 3" WIDE with linkages, it causes an annoying blindspot everytime they swipe!!! Also..keep in mind I have driven in the rain less than I have fingers...so all of you that say "you don't even notice it", it's probably just because you're ACCUSTOMED to it!
They STINK!
Ps...for the fanbois, has everyone forgotten about the thread trashing the wipers because there are so few aftermarket wiper blades/inserts available for them?
Now it's wiping the dust and pollen of your windshield....but...OH!--NO STREAKS! lolol!!!!!!
Gimme a break!
You act like you can't clean the blade while it's parked at the bottom. I wipe my blade/windshield interface pretty much every time before turning on the wipers for the first time and there is NO PROBLEM doing it on the LS with them parked. The blades will lift an inch or so off the glass in the down position and you can slide a microfiber cloth under there no problem.
I change my wiper blades in December of every year as a common maintenence item. Do it by just removing the the wiper assembly from the arm in the down position. Just flip the lever and remove and then replace the blade. Anybody could do it.
No big deal. Wonderful design.
